Message Center
don't worry, you guys aren't missing much by not having the advanced message center. It doesn't even tell you the instantaneous MPG's in numbers, rather it's a series of like 5 bars. Basically it's either 5 bars when you're coasting, and 1 or 2 bars when you're on the throttle/gas. really helpful....
I read "How do you reset the rpm gauge on a f150?
Press and hold the reset button. While holding the reset button, turn on the ignition key but do not start the car. At the bottom of the dashboard, you should see a sign that says "sweep gauges" or watch as the gauges begin resetting to the correct positions. Sep 7, 2022"
Test mode shows a lot of stuff but the sweep gauges doesn't rest my RPM like it says it would. I have a 2011 Lariat. When engine is idle, my rpm shows below 0. Start the engine with the test mode, rpm is correct. Shows the digital output. I don't know how to reset the rpm gauge.
