Anybody add AC Power Plug to their truck?
Old Jun 13, 2010 | 05:25 PM
rivydzl's Avatar
Originally Posted by carryyourbooks
i bought an inverter for the laptop and decided to plug the ol' dewalt charger in while in my service van. drained the battery. be careful. the ol' charger be drainin' some juice. works fine if you only leave it plugged in while driving.
I had the same problem. I put in a 400 watt power inverter to run my xbox 360. It slowly killed the battery and alternator, and then the power inverter itself went bad. So i got a larger power inverter, added two Optima blue tops in addition to the stock battery, ran the inverter off them as well as the 110v I put in the rear bumper, threw in a battery isolator to protect the stock battery to make sure I can always start, and had a 250 peak amp alternator installed. Problem solved. The only thing I installed myself were the batteries with some thick gage wire because I make a horrible electrician. But I would look into upgrading your entire electrical system to make sure you don't have any issues. Look up OGTerror. He has made MAJOR electrical mods himself. He has a couple pairs of outlets in the center console and a massive power inverter.
Old Jul 19, 2010 | 01:07 PM
Campin's Avatar
I have a pretty nice mobile office set up in my Ford. It uses a 300 watt sine wave power inverter. This is best for most sensitive loads...
Here is a link to a good guide...
http://www.outsidesupply.com/definit...ter-guide.aspx
I like hard wiring but sometimes it is easier just to plug into the inverter.
