Sync problems...
I think I am having the same proplem. I get in and go and my phone connects like normal. Then just about a minute later the phone just disconnects. I have reconnected again and it still disconnects. I still havent taken the time to mess with it.
I would try turning off phonebook auto download.
That'd be nice but hey haven't come out with a fix to the indexing problem in over six months so I'm not gonna hold my breath.
Does your phone have iOS4? Just about everything they said would work with my iPhone did until I installed iOS4 (indexing took for-frakking-ever). Now the Ford folks are saying they're working on a Sync update to fix the problems.
^ This
I dont know why I would want to turn it off...I have changed nothing and it worked fine until a week ago. It just started doing it. I should have time this weekend to mess around with it. Until then, maybe the OP will have some insight.
Sync is a computer system. Perhaps the phonebook (on either the phone or in Sync) or pairing is corrupt? Has your phone OS been updated? Have you added any entries?
Simply giving you a suggestion that has fixed a lot of similar problems.
If you don't want to do that, I would recommend a master reset.
I had never had a problem losing connection until I updated my SYNC software. Now, it only connects about half the time when I start the truck. I have to turn off the bluetooth on my phone and then turn it back on for it to work. This is remarkably annoying. I am a salesman, and I am in and out of my truck constantly throughout the day.
SYNC works great with my iPhone 3GS, only problem is I cant figure out the text message part which is a feature I was looking forward to. Any suggestions? Ive tried and it pretty much said not supported if I remember right. =/
Check out this chart. It tells you text messaging is not supported for your phone:
http://www.nsapp.fordtechservice.dea...N_iop_1_30.pdf
Not necessarily. The iTunes default is to not download or install operating system updates unless you request it. I haven't checked but I suppose you can change that and make them automoatic.
