SYNC problem
Old Mar 30, 2010 | 07:35 PM
Blackout150's Avatar
SYNC problem
Hey everybody, today I got into my truck after work and my phone wouldn't connect to the SYNC. It worked fine until today. Any suggestions?
Old Mar 30, 2010 | 07:39 PM
shotgunz's Avatar
I assume you have already toggled the phone BT off and on.
If so, then try pulling the Sync fuse for 1-3 minutes. If that doesn't work then
1. Master reset (Sync)
2. Delete Sync from your phone
3. Re-pair the phone
Old Mar 30, 2010 | 09:33 PM
kskr's Avatar
I had that same problem a couple of times on my 2010 H-D. I just re-paired the phone to the truck and it worked fine. If this continues I will make a trip to the dealer.
Old Mar 30, 2010 | 11:03 PM
Justi's Avatar
You can actually download sync updates directly from syncmyride.com and then install them yourself. It was a very straightforward and easy process that beats the crap out of taking it into the dealer and losing your truck for a day.
Old Apr 1, 2010 | 12:25 PM
Matchaponix's Avatar
Battery
Pull the battery out of the phone, then put it back in. Hard re-boot.
That worked for me.
Old Apr 1, 2010 | 12:32 PM
sml175's Avatar
Same here, had to re-find the bluetooth about 5 times
Now it works. I had to "DELETE" Sync, before it would work. I tried it just by re-connecting and it did not work, you must delete "Sync" off your phone first, then re-find it. It is like clearing the cache on a web browser.
