Leveling kit install on 09+ F150's...
I did mine last month and we spent about 30 min trying to get it in and then I reread the the directions and it said to place a bottle jack on top of the lower control arm. once we did that it went right in. The first side took about an hour and a half the second took about a half hour.
Ya exactly! I guess when all else fails read the directions. AS was aware of the problem with the 09/10 since ford changed from the aluminum. At first we were trying to compress the springs with tow straps> bottle jack worked like a charm.
hey guys i know this is a little off subject but harbor freight and ford have been sending out coupons for discounts up to 75% on their tools. very good prices! this isnt cheap tools either...we are talking air compressors, cherry pickers, etc...
According to both the printed instructions that came with my 2" aluminum kit and the somewhat older instructions available on their website, which does not mention the 2" kit, neither mention anything about using a bottle jack; they only refer to using a floor jack under the LCA in order to raise the knuckle to engage and hold the upper ball joint in place to install the nut.
There is a photo in the printed instruction sheet that shows a pry bar being used between the LCA and the bottom of the strut end to get it back in.
Once I get my 3" rear block kit, I will start with the front and report back my experience...
I've done 2 so far for friends, getting ready to do my own next weekend. I used a port-a-power instead of the bottle jack, but same result. But not everybody has access to a port-a-power. I can see where it would be a bear without something to open it up more without some kind of a hydraulic tool.
Although I've already installed my 2" spacer, I think I need a little more lift, either with a 2.5" or in conjunction with Bilstein 5100's. I just can't see how a thicker spacer could fit with the tools I used (pry bars only) for my 2" HBS.
Question for you guys. Does the 2" actually level the truck? And/or does the 2.5" make the front sit a bit higher. I just got a 2010 and it needs the leveling kit. Thanks for the help.
@Pip: I'm curious what leverage points you used to place the Port-a-Power?
That would help, thanks!
Finally settled on which rims I want and placed the order today through my local Discount Tire. They are located somewhere in Alabama and will take about a week or so to be delivered.
20x9 with +25mm offset should fit right in with no trimming in combo with the 2" lift.
