2" AS Spacer or 2 1/2" AS Spacer
Old Feb 22, 2010 | 02:11 PM
  #31
150blazzin's Avatar
If you take a tape measure and measure from the ground to the rear wheel well and subtract that from the same measurement of the front wheel well, its usually 2 inches difference. Whatever it is, say 1.5 or 2 inches, go with the right kit that fits your truck.
I have a 2009 screw XLT and I put a 2 inch leveling kit on mine and its leveled out perfect (I believe 37 inches for both wheel wells)
Hope this helps
Old Feb 22, 2010 | 10:10 PM
  #32
GS357's Avatar
Originally Posted by racinwarrior
just did a 2.5 inch front and 1.5 rear. sits exactly level. you can order the 1.5 2wd kit and use the u-bolts from 04-08 4wd
Can you post some pics?
Old Feb 23, 2010 | 10:20 AM
  #33
racinwarrior's Avatar
yeah ill post some later tonight. i dont have any before pics. just search the albums for a royal red 2009 platinum and mine sits the same. do you want pics of the rear blocks or just the truck?
Old Feb 24, 2010 | 07:11 PM
  #34
GS357's Avatar
Both if possible. I would like to do the same 2.5 front and 1.5 rear. Just looking for the right kit or parts for both front and rear.
Old Feb 25, 2010 | 08:20 AM
  #35
https://www.f150online.com/forums/me...4935-red5.html
BEFORE (ANOTHER USER)
AFTER
Old Feb 25, 2010 | 11:15 AM
  #36
White Platinum's Avatar
What's the size of the factory rear blocks on a 4x4 platinum. I thought they were bigger than 1.5
Looks good RW very nice
Old Feb 25, 2010 | 11:31 AM
  #37
thanks man
i think the factory blocks are only about an inch
Old Feb 25, 2010 | 11:41 AM
  #38
Auto Springs website says they are 1 5/8 for 4x4 and to use the 3" blocks for 4x4.
Now I am confused. Guess I need to measure. I was thinking about adding a little in the A$$ but not a 3" block.
Old Feb 25, 2010 | 01:33 PM
  #39
what i did was buy the kit for the 2wd its 1.5". The u-bolts that come with the blocks are to short so i used a set from 2004-2008 4wd that i had on the shelf. worked fantastic
Old Feb 25, 2010 | 03:03 PM
  #40
Mickeymeanie's Avatar
So does this mean you stacked the 1.5" AS block on top of what I presume is a stock block that is 1.5"... total of 3"?
Old Feb 25, 2010 | 03:21 PM
  #41
shiny black block on top is new
Old Feb 25, 2010 | 04:08 PM
  #42
so you stacked to make 3". Not sure I like the stack. Prolly just buy the rear for mine and see if I like it.
Thx for the pic RW
Old Feb 25, 2010 | 05:01 PM
  #43
Thx for the pic RW
Agreed... while it's probably perfectly fine, I'm one of those people that would worry about it constantly... every little noise I would freak me out... I'd rather have one solid 3" block...
Is the stock block on the 4X4 the same size as the stock block on a 4X2? You bought the 1.5" 4X2 rear block kit, so I'm wonderinh if the stock 4X2 is 1" and this gives a .5" lift... which I think is all I would want/need for my 4X2...
Old Feb 26, 2010 | 07:46 PM
  #44
04 kbgt's Avatar
im susprised no one mentioned the bds spacers look like pretty good quality, and they also offer a rear block setup so it will lift the rear 1" over stock
