Cant Get Leveling kit to fit in correctly
Old Feb 14, 2010 | 11:27 PM
racinwarrior's Avatar
hey guys-
I got a leveling kit on ebay a few weeks back. its a 2.5 inch that said 04-09 2x4 and 4x4.
i installed a 3 inch on my old 2006 without problems, but i am having issues installing this on my 09
i took everything apart and pulled the strut completely out. screwed on the stud extensions and dropped the spacer on. I could not get the strut to fit back in no matter what i tried. this kit does not require the strut to be installed backwards. they give you stud extenstions and you reinstall the strut in the factory orientation. i even disconnected the sway bar to get more room. any ideas. i needed about another inch for the strut to be able to fit back in.
Old Feb 15, 2010 | 04:21 PM
scott6809's Avatar
I've read a couple of threads about it being a PIA, but they do go on. Here is a link that may help you...
https://www.f150online.com/forums/20...it-issues.html
Old Feb 16, 2010 | 02:22 PM
winnipegk5's Avatar
I dropped the lower control arms by removing the two big bolts and the strut went back in super easy. Less than 30 minutes to do the second one after I figured it out. Just used the jack to hold the control arm up. Jacked it back into place and slid the two bolts back through easily.
Old Feb 17, 2010 | 08:43 AM
thanks. thats probably what i will do this weekend
Old Feb 17, 2010 | 09:46 AM
04 Tan Scab's Avatar
What brand kit are you trying to install?
