Bakflip Drain Tube Installation
Rear drains
Hi guys,
The natural stance of any ford truck is to be higher at the tailgate end and lower at the front of the truck. Water, always finding it's lowest level, will therefore naturally flow forward towards the cab when it gets into the bakflip rails. When the truck is parked up a hill, water will then flow backwards towards the tailgate and simply out the back of the bed. It's for this reason that BAK includes drain tubes in the front corners and never included drains at the rear end of the truck.
With this all said, the OEM Ford BakFlip's do indeed have OPTIONAL drain tubes in the rear corners that drain out of the pre-existing hole in the side wall of the truck. This is usually where a bed extender would fit. When a bed extender is present, then the drain tubes just tuck behind the 2 attachment points where the tailgate meets the floor of the bed. This allows the water to drain out the back of the tailgate as well.
In my opinion it's a bit redundant. It's certainly not that BAK skimped on the inclusion of a rear drain tube, it's just that we don't agree that it's a necessity.
I am open to suggestions though. It's what keeps us moving forward and making great products.
All the best,
Julian Maimin
BAK
All the best,
Julian Maimin
BAK
One solution that looks like it would provide the needed rear drains & be compatible with the factory bed extender is to provide a 90 degree elbow at the rear drains. If the next size smaller tube (1/2" ID vs 5/8" ID) is used, it could be routed into the smaller existing holes on the side of the bed channel located below the rails. This would allow water to be routed outside of the bed and eliminate the the interference between the drain tubes & the factory bed extender. This would complete the design & make a truly great cover.
Obviously driving conditions, rain conditions, etc, could lead to what the above post is saying.
In my experience through rain, car washes, etc, I have had VERY LITTLE moisture in the bed. None in the front, ever. I've had what I would say is a very small amount of water in the back after ridiculously heavy rain or high-pressure car wash. I've never had enough water that would actually pool and move around in the bed as you drive. More like moisture, water droplets, if that makes any sense.
All in all for something so low profile, it does an amazing job at keeping the bed dry - in my humble opinion.
Thanks for all the replies and suggestions!
I ended up ordering the Ford OEM cover from the dealer yesterday. The dealer gave me a decent discount and I was able to get it for only $25 more than my local aftermarket store was selling the regular HD. The $25 seemed well worth it for the 3-year warranty and slightly more "refined" components (according to Bak).
I'm pretty sure I'll end up routing the drain tubes into the stake pockets for a nice clean look. I spoke to Line X and they just said to drill my holes slightly larger than I need because their liner will fill them in a little bit.
