SYNC volume question....
Old Sep 26, 2009 | 02:17 PM
Jeff T's Avatar
I set the radio volume where I like it then hit the button on the steering wheel to make a call. The volume immediately drops. I turn it up make the call and when the call is over and the radio returns the volume drops again.
Anyway to keep the volume constant?
Thanks!
Old Sep 26, 2009 | 07:37 PM
dilloncawthon's Avatar
im sure there is but why would you want music on while on the phone
Old Sep 26, 2009 | 07:42 PM
stormtech's Avatar
I don't touch the volume control before, during, or after a call, and it all works fine for me -
Hit the call button - music stops
During call - music off
End call - music comes back to where it was
Old Sep 26, 2009 | 07:48 PM
Jeff T's Avatar
Maybe I didn't explain well enough....
Here's what happens in my truck:
During call - music off, but volume lower than where it was when radio was on causing me to increase the volume to hear the call.
End call - music comes back to a lower volume than it was prior to the call.
I'm constatntly adjusting the volume...
Old Sep 26, 2009 | 08:06 PM
stormtech's Avatar
That is strange -
Maybe it has something to do with your phone as my phone volume is plenty loud without touching the volume control.
Old Sep 26, 2009 | 08:09 PM
d4studmuf1n's Avatar
i was wondering the same thing, i have to turn the volume almost all the way up when talking on my phone, but it goes back down when it goes back to music
Old Sep 26, 2009 | 08:13 PM
Jeff T's Avatar
That's what I'm talking about!! Goes down with me adjusting anything! I've got and iPhone.
Old Sep 26, 2009 | 08:14 PM
LLeonha104's Avatar
Jeff, Have you updated your Sync system ?
Old Sep 26, 2009 | 10:54 PM
Jeff T's Avatar
Truck is only a week old, so no.
Old Sep 27, 2009 | 12:28 AM
RoundII's Avatar
My Sync is updated and have the same issue. Tons of people are complaining about this problem...not sure which carrier or type phone they are using, buI have a Crack Berry with ATT.
Some phones evidentially have the ability to set the phone volume when using a Bluetooth device and some people have found that this will remedy their loss of volume. No dice for me.
One person had this to say:
The reason that your phone volume seems low, especially relative to the volume of say your radio or compact disc, is because the default setting for speed-controlled volume for non-phone audio is set to max. When you receive a phone call, it does not use the compensated speed-controlled volume, and instead uses the "normal" or "minimum speed-controlled volume."
How did I remedy this? Well, I just set the speed-controlled volume to setting 1, which is the lowest it can be. This means that when you're driving at a higher speed, the non-phone audio system won't automatically increase its volume. If you want it to be louder, make it louder - but chances are you wont even need to. So, when you get a phone call, your phone volume will be at the exact same volume as the radio or compact disc volume!
Let me know if this helps....
RoundII
Old Sep 27, 2009 | 11:28 AM
LLeonha104's Avatar
Here is a Ford TSB that might help.
TSB 09-13-5
Page 1 of 6
Printable View (31049 KB)
TSB 09-13-5
 SYNC - CALL SOUND QUALITY/BACKGROUND NOISE ISSUES AND/OR VOICE RECOGNITION DIFFICULTIES WHILE DRIVING
Publication Date: June 23, 2009
FORD: 2008-2009 Focus, Fusion, Taurus X, Taurus, Edge, Explorer Sport Trac, Explorer 2009 Escape Hybrid, Escape, Expedition, F-150, F-Super Duty, Flex LINCOLN: 2008-2009 MKZ 2009 MKS 2008-2009 MKX, Navigator MERCURY: 2008-2009 Milan, Sable, Mountaineer 2009 Mariner Hybrid, Mariner
ISSUE:
Some customers of 2008-2009 SYNC equipped vehicles may express concern with their call sound quality while using the SYNC microphone, complaints of excessive background noise during a phone call, and/or issues with voice recognition accuracy while driving.
ACTION:
Follow the service procedure to correct the condition.
SERVICE PROCEDURE
The following service procedure involves updating the Accessory Protocol Interface Module (APIM) software level and installing an external alternate SYNC microphone attached to the headliner.
NOTE: THIS PROCEDURE DOES NOT APPLY TO DEALER-INSTALLED SYNC SYSTEMS.
Do not perform Step 1 if vehicle is already equipped with SYNC 2.0 (911 and Vehicle Health Report) or has been upgraded to consumer interface processor (CIP) level 9L3T-14D544-AE. To determine the current APIM software level, Refer to the Professional Technician Society (PTS) website, enter the VIN in OASIS, click the GO button, and select the SYNC button.
1.Reprogram the APIM to CIP software level 9L3T-14D544-AE. For additional information Refer to other SYNC TSB's and WSM, Section 418-01. Service Pack files may also be obtained at www.syncmyride.com.
When diagnosing a concern related to voice recognition (VR) difficulties, instruct the customer to test VR functionality while the vehicle is parked. If customer concerns are still present, this procedure will not yield an improvement, and the service procedure should not be performed. Instead, Refer to the SYNC supplement guide and www.syncmyride.com for additional VR tips to assist customer.
The VR experience can be improved with user training and making improvements to the phone book entries (longer entries make the system more robust). Ensure the customer does not try to speak too loud or slow and remove any objects hanging on the rear view mirror as this will reduce system effectiveness.
When diagnosing a concern related to call sound quality, expect marginal improvements for calls described as speaking in a tunnel, chamber, etc. Expect substantial improvements for complaints where the call audio seems to drop out intermittently.
NOTE: THIS REPAIR WILL CHANGE THE APPEARANCE OF THE VEHICLE INTERIOR. REFER TO THE PHOTOGRAPHS FOR THE APPLICABLE VEHICLE LOCATED IN THIS PROCEDURE. DO NOT PERFORM THIS REPAIR WITHOUT CUSTOMER APPROVAL PRIOR TO PROCEEDING WITH MICROPHONE INSTALLATION.
2.Install SYNC microphone service kit. Installing the kit includes mounting an external microphone directly to the headliner and splicing in a jumper harness to the vehicle's existing wiring harness. The existing SYNC microphone will no longer be functional. a.Refer to the appropriate vehicle line and microphone illustration(s) below for microphone installation and wire splicing locations. Refer to Wiring Diagram (WD), Section 5-1 for recommended splicing methods. b.Ensure the SYNC microphone wires are secure and do not interfere with vehicle operation or functionality. c.The microphone is directional. Make sure the microphone is always positioned so wire length is minimized from view. When installing the microphone adjacent to trim, place microphone as close to trim as possible to help minimize visible wire.
2008-2009 Edge / MKX
1.Remove the protective backing from the adhesive on the microphone and attach the microphone. (Figure 1)
 Firmly press the microphone into place.
 Ensure the microphone is parallel and adjacent to overhead console trim.
Figure 1 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable up through existing hole in the headliner, and over to the driver side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connectors 210 and 211 in the left A-pillar. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMM13 (YE-GN), RMM13 (BU), and DMM13 (shield) from C211. Cut the three circuits on the female side of the connector (14334 harness). 7.Identify circuits CBP41 (BU) and GD133 (BK) from C210. 8.Splice the five jumper harness wires into the following circuits:
 Blue jumper harness wire to CBP41 (BU) and any black jumper harness wire to GD133 (BK).
 Ensure original circuits remain connected in splice.
 Yellow jumper harness wire to VMM13 (YE-GN) and remaining black jumper harness wires to RMM13 (BU) and DMM13 (shield).
9/27/2009 http://www.fordtechservice.dealercon...MUS~LEN/3606/t...
TSB 09-13-5
Page 2 of 6
 Only splice into the cut wires heading in the direction of the connector. Tape off and secure the cut wire ends heading up the A-pillar as they are no longer used. 9.Attach the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable over the front of the headliner.
2009 Escape / Mariner
1.Remove the protective backing from the adhesive on the microphone and attach the microphone as shown in the illustration (Figures 2 and 3). Firmly press the microphone into place. Ensure the microphone is parallel and adjacent to overhead console trim (if equipped), or positioned directly above A-pillar on headliner if not equipped with an overhead console. Proceed to Step 5 if not equipped with an overhead console.
Figure 2 - Article 09-13-5
Figure 3 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 501-05 for additional information. 3.Route microphone cable through existing hole in the headliner, and over to the driver side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 214 in the left A-pillar. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMM13 (YE-GN), RMM13 (BU), and DMM13 (shield) from C214. Cut the three circuits on the female side of the connector (14334 harness). 7.Identify circuits CBP41 (BU) and GD182 (BK-GY) from C214. 8.Splice the five jumper harness wires into the following circuits:
 Blue jumper harness wire to CBP41 (BU) and any black jumper harness wire to GD182 (BK-GY).
 Only splice into the cut wires heading in the direction of the connector. Tape off and secure the cut wire ends heading up the A-pillar as they are no longer used. 9.Connect the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable over the front of the headliner.
2008-2009 Navigator / 2009 Expedition
1.Remove the protective backing from the adhesive on the microphone and attach the microphone. (Figures 4 and 5)
 Ensure the microphone is parallel and adjacent to overhead console trim (if equipped), or positioned directly above A-pillar on headliner if not equipped with an overhead console.
 Proceed to Step 5 if not equipped with an overhead console.
Figure 4 - Article 09-13-5
Figure 5 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and over to the passenger side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 298 located behind the dash panel on passenger side. Refer to online WD, Section 124-1 for links to location and connector views.
TSB 09-13-5
Page 3 of 6
6.Identify circuits VMN07 (GY), RMN07 (VT), and DMN07 (shield - BK) from C298. Cut the three circuits on the male side of the connector (17C712 harness). 7.Identify circuits CBP31 (BU-OG) and GD133 (BK) from C298 (2008 Navigator only). Identify circuits CBP41 (BU) and GD133 (BK) from C298 (2009 Expedition/Navigator only). 8.Splice the five jumper harness wires into the following circuits:
 Blue jumper harness wire to CBP31 (BU-OG) and any black jumper harness wire to GD133 (BK) for 2008 Navigator only. Blue jumper harness wire to CBP41 (BU) and any black jumper harness wire to GD133 (BK) for 2009 Expedition/Navigator only.
 Yellow jumper harness wire to VMN07 (GY) and remaining black jumper harness wires to RMN07 (VT) and DMN07 (shield - BK).
 Only splice into the cut wires heading in the direction of the connector. Tape off and secure the other cut wire ends as they are no longer used. 9.Connect the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable above the headliner.
2008-2009 Explorer / Explorer Sport Trac / Mountaineer
1.Remove the protective backing from the adhesive on the microphone and attach the microphone. (Figure 6)
Figure 6 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and over to the driver side A-pillar. It may be necessary to slightly drop headliner run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 248 in the left A-pillar. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify and cut circuits VMN07 (GY), RMN07 (VT), and DMN07 (shield) from C248. Cut the three circuits on the female side of the connector (14334 harness). 7.Identify circuits CBP05 (YE) and GD143 (BK-VT) from C248. 8.Splice the five jumper harness wires into the following circuits:
 Blue jumper harness wire to CBP05 (YE) and any black jumper harness wire to GD143 (BK-VT).
 Yellow jumper harness wire to VMN07 (GY) and remaining black jumper harness wires to RMN07 (VT) and DMN07 (shield).
2009 F-150
1.Remove the protective backing from the adhesive on the microphone and attach the microphone. (Figure 7)
 Ensure the microphone is parallel and adjacent to overhead console trim or front lamp.
Figure 7 - Article 09-13-5
2.Lower the overhead console or front lamp. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and temporarily tuck excess wire into headliner to the rear of the console or lamp. 4.Install overhead console or front lamp; ensure microphone cable enters the overhead console or front lamp trim directly behind microphone as shown. 5.Gain access to connectors 314 and 315 in roof panel near left hand side. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMM13 (YE-GN), RMM13 (BU), and DMM13 (shield) from C314. Cut the three circuits on the female side of the connector (14358 harness). 7.Identify circuits CBP41 (BU) from C315 and GD133 (BK) from C314. 8.Splice the five jumper harness wires into the following circuits:
 Only splice into the cut wires heading in the direction of the connector. Tape off and secure the other cut wire ends as they are no longer used. 9.Attach the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable above the headliner.
2009 F-Super Duty
1.Remove the protective backing from the adhesive on the microphone and attach the microphone as shown in the illustration. (Figure 8) a.Firmly press the microphone into place. b.Ensure the microphone is parallel and adjacent to overhead console trim. c.This repair is not recommended for vehicles not equipped with an overhead console.
TSB 09-13-5
Page 4 of 6
Figure 8 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and over to the passenger side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 264 in the right A-pillar. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMM13 (YE-GN), RMM13 (BU), and DMM13 (shield - BK) from C264. Cut the three circuits on the female side of the connector (17K745 harness). 7.Identify circuits CBP41 (BU) and GD133 (BK) from C264. 8.Splice the five jumper harness wires into the following circuits:
 Yellow jumper harness wire to VMM13 (YE-GN) and remaining black jumper harness wires to RMM13 (BU) and DMM13 (shield - BK).
 Only splice into the cut wires heading in the direction of the connector. Tape off and secure the other cut wire ends as they are no longer used. 9.Connect the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable above the front of the headliner.
2009 Flex
1.Remove the protective backing from the adhesive on the microphone and attach the microphone as shown in the illustration. (Figure 9)
Figure 9 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and over to the passenger side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 925 in the right A-pillar. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMM13 (YE-GN), RMM13 (BU), and DMM13 (shield) from C925. Cut the three circuits on the female side of the connector (14334 harness). 7.Identify circuits CBP41 (BU) and GD133 (BK) from C925. 8.Splice the five jumper harness wires into the following circuits:
 Only splice into the cut wires heading in the direction of the connector. Tape off and secure the other cut wire ends as they are no longer used. 9.Attach the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable above the front of the headliner.
2008-2009 Focus
1.Remove the protective backing from the adhesive on the microphone and attach the microphone as shown in the illustration (Figure 10). Firmly press the microphone into place. Ensure the microphone is parallel and adjacent to the dome lamp trim. 2.Lower the dome lamp assembly. Refer to WSM, Section 417-02 for additional information.
Figure 10 - Article 09-13-5
3.Route microphone cable up through existing hole in the headliner, and over to the passenger side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install dome lamp assembly; ensure microphone cable enters the dome lamp trim directly behind microphone as shown. 5.Gain access to connector 934 in the right A-pillar. Refer to online WD for location and connector views. 6.Identify circuits VMM13 (YE-GN), RMM13 (BU), and DMM13 (shield) from C934. Cut the three circuits on the female side of the connector (14334 harness). 7.Identify circuits CPL60 (BN-YE) and GD161 (BK-YE) from C934. 8.Splice the five jumper harness wires into the following circuits:
 Blue jumper harness wire to CPL60 (BN-YE) and any black jumper harness wire to GD161 (BK-YE).
 Only splice into the cut wires heading in the direction of the connector. Tape off and secure the other cut wire ends as they are no longer used. 9.Attach the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable over the front of the headliner.
TSB 09-13-5
Page 5 of 6
2008-2009 Fusion / Milan / MKZ
1.Remove the protective backing from the adhesive on the microphone and attach the microphone as shown in the illustration. (Figure 11) a.Firmly press the microphone into place. b.Ensure the microphone is parallel and adjacent to overhead console trim.
Figure 11 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and over to the passenger side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 913 in the right A-pillar. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMM13 (YE-GN), RMM13 (BU), and DMM13 (shield) from C913. Cut the three circuits on the female side of the connector (14334 harness). 7.Identify circuits CBP02 (GN) and GD139 (BK-YE) from C913. 8.Splice the five jumper harness wires into the following circuits:
 Blue jumper harness wire to CBP02 (GN) and any black jumper harness wire to GD139 (BK-YE).
2008-2009 Taurus / Sable / Taurus X
1.Remove the protective backing from the adhesive on the microphone and attach the microphone as shown in the illustration. (Figure 12)
Figure 12 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and over to the driver side A-pillar. It may be necessary to slightly drop headliner to run microphone cable. Refer to WSM, Section 501-05 for additional information. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 925 in the left A-pillar. Refer to online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMN02 (WH-BN), RMN02 (VT-BN), and DMN07 (shield) from C925. Cut the three circuits on the female side of the connector (17K745 harness). 7.Identify circuits CBP41 (BU) and GD133 (BK) from C925. 8.Splice the five jumper harness wires into the following circuits:
 Yellow jumper harness wire to VMN02 (WH-BN) and remaining black jumper harness wires to RMN02 (VT-BN) and DMN07 (shield).
2009 MKS
1.Remove the protective backing from the adhesive on the microphone and attach the microphone as shown in the illustration. (Figure 13) a.Firmly press the microphone into place. b.Ensure the microphone is parallel and adjacent to overhead console trim.
Figure 13 - Article 09-13-5
2.Lower the overhead console. Refer to WSM, Section 417-02 for additional information. 3.Route microphone cable through existing hole in the headliner, and out the front of the headliner above the rear view mirror. 4.Install overhead console; ensure microphone cable enters the overhead console trim directly behind microphone as shown. 5.Gain access to connector 911 at the rear view mirror. Refer to the online WD, Section 124-1 for links to location and connector views. 6.Identify circuits VMN02 (WH-BN), RMN02 (VT-BN), and DMN07 (shield) from C911. Pull back the black harness sleeve and cut the three circuits near C911 or if equipped with a headlamp control module-2 (HCM-2), remove the HCM-2 access cover and cut circuits under trim cover. Refer to WSM, Section 417-01 for additional information. 7.Identify circuits CBP41 (BU) and GD133 (BK) from C911.
TSB 09-13-5
Page 6 of 6
 Only splice into the wires heading away from the connector. The wires heading into the connector (mirror) are no longer used.
 Ensure the wiring is neatly routed from the splice locations into the headliner, following the existing wire harness routing from mirror to headliner. 9.Attach the microphone connector to the jumper harness connector. 10.Bundle and tuck the remainder of the microphone cable above the front of the headliner.
PART NUMBER PART NAME 8T4Z-19A391-A Microphone Kit
OTHER APPLICABLE ARTICLES:
08-21-2
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME MT091305 Claim Diagnosis And Labor Performed As Actual Time. Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE 17700 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2009 Ford Motor Company
Old Sep 27, 2009 | 11:31 AM
LLeonha104's Avatar
Exclamation Sync
Your truck might only be a week old, but when was it built, there is always software updates. Have you gone to Sync my Ride dot com ?
Old Sep 27, 2009 | 11:36 AM
Jeff T's Avatar
It was made in July. Went on the website last night after your post. Still trying to nav through the page.
Old Sep 27, 2009 | 12:39 PM
hemigod's Avatar
If you have a 2009 with VHR and 911 assist, then you have version 2.0 of the sync software. There are no further updates to version 2.0 at this time. 2009 vehicles do not support version 3.0. The forums on syncmyride.com indicate that an upgrade to version 2.0 "might" be available by year end.
FYI - your truck has a build date later than mine and mine has sync version 2.0 installed from the factory, so yours probably does too.
I have not tried a phone call yet in my FX4, however in my 2009 MKS with sync and nav, I don't have the volume problem. I have the speed compensation volume control set to 3 in the MKS. Other MKS users are reporting the same problem on the MKS forum I belong to, so it's not just you or these trucks.
Old Sep 27, 2009 | 04:37 PM
AWorthington's Avatar
If the 2009 does not support 3.0 then do the 2010s support it? What is the difference between 2.0 and 3.0 Sync version? I tried to look it up on syncmyride.com but could not find any info on the different versions.
