Has anyone swapped the black door handle plates for body colored???
My new truck arrived yesterday, pics later, I like the Pueblo Gold more than I thought I would. but man would body color door handle look better than the black.
Anyone swap these yet? Pricey? Difficult?
Thanks!
Thanks!
Cost anyone?
yes, need to take off door panels.
I don't think you can already buy the standard handles painted to match (PTM), you'd have to get a body shop to paint them. and it would be best to buy the smooth, paintable handles from Ford first rather than trying to use the stock textured handles. This was the case for 04-08 and I'm sure it's the same for 09.
But the handles that do come already PTM from Ford are the Mark LT/Platinum handles. They have a painted bucket but the pull straps are chrome. Tasca has the Screw set with tailgate handle for around $315+shipping.
http://www.trademotion.com/partlocat...egoryID=122674
but those are the 04-08 handles. The 09 handles look exactly the same so in theory the older handles should work but it would be best to double check first with Tasca.
To the OP, just make sure you see the way the handle "rod" fits the handle BEFORE you remove it. I wasn't paying attention on the driver's door handle and you can install it 180 deg off...so while it fit - the door wouldn't open close after I had everything reassembled and had to take it apart again and reverse the rod. (This will make sense once you take off the door panel and start to remove the buckets). Another thought is that if you can't get the Pueblo Gold color you will be getting another color and painting it to match...I believe I've seen both on the '09's body matching buckets with the chrome handles (Plat/Lariat models) and I've seen the full body color buckets and handles...choose which look you like the best but the chrome handles might hold up better than the "repainted" handles....
