Bad news for Modders (Raptor)
Old Aug 25, 2009 | 05:41 PM
Deano-FX4's Avatar
well we ordered in a Raptor grill assy as soon as the part number was avialable and it won't fit on a standard F150 you would have to replace the whole hood.
but for your FYI the grill was $1000 retail and a hood is about $1500 CND plus paint.
Old Aug 25, 2009 | 05:54 PM
cdiddy4224's Avatar
someone will eventually clone it and it will be available to the masses...just takes time!
Old Aug 25, 2009 | 06:26 PM
Raptor05121's Avatar
HOLY ****
Old Aug 25, 2009 | 07:38 PM
Deano-FX4's Avatar
maybe
yup
but our dealer isn't a SVT dealer so we can't order the Raptor so we are thinking of building a clone for the showroom but were not sure how deep we are going to go with it. if it will just be apearance or if we will be doing the suspension mods as well. if we do do it, it should be a fun build.
Old Aug 25, 2009 | 07:41 PM
doesnt surprise me really
Old Aug 25, 2009 | 08:36 PM
SteveVFX4's Avatar
didn't you guys/dealer look at the pictures of the Raptor first? It is pretty obvious the grille and hood is different from the standard F150. The hood wraps down and the grille goes straight across and lines up with the top of the headlights. as you know, the standard F150 grilles extend up higher in the middle, above the top of the headlights.
Old Aug 25, 2009 | 08:38 PM
JRVicHammer's Avatar
Isn't the Raptor 7 inches wider than a regular F150 or is it just the track width that is wider?
Old Aug 25, 2009 | 09:10 PM
Brew1's Avatar
Yep it was pretty easy to see it wouldn't fit. But what about the headlights???
Old Aug 26, 2009 | 12:07 AM
alomar's Avatar
The entire frame is 7 inches wider, thus everything else being wider. So next to nothing from a 2010 or 2009 150 will transfer exterior wise
Old Aug 26, 2009 | 12:58 AM
Deano-FX4's Avatar
it was all about reasearch
but thnx for the insightful input
Old Aug 26, 2009 | 01:03 AM
broncobran68's Avatar
The entire frame is 7" wider? While I admit I don't know exactly where the raptor gets its width, I know the frame isn't wider. It would cost a ton to make a frame specifically for the raptor. I doubt that the rear axle is even wider. It's just some 12.5" wide tires mounted on low backspacing wheels, with some larger fenders to keep the rocks from flying. So virtually everything will transfer.
Old Aug 26, 2009 | 08:08 AM
Deano-FX4's Avatar
just to clarify we were well aware of how the hood is, we wanted to see if we could mod the Raptor grill into the center section of the F150. and the only way to do that was to buy one.
the Raptor grill fits the demensions but the bolt pattern makes it a much bigger mod them we were hoping for..
Old Aug 26, 2009 | 11:33 AM
newmandl's Avatar
I pulled this from the specs off of the Ford web site. You will notice that the Raptor is an overall width of a little more that 7" (I suspect that it is the offset on the tires and the tire width). But, you will notice the overall width with mirrors are exactly the same. This indicates that the truck itself is the same frame/body. Just my observation.
DIMENSIONS
EXTERIOR
REGULAR CAB SUPERCAB SUPERCREW SVT RAPTOR SUPERCAB
4x2/4x4 4x2/4x4 4x2/4x4 4x4
A. Overall height
with 5.5' box
— — 74.3"/76.2" 78.4"
with 6.5' box
74.6"/76.0" 71.5"/75.9" 74.3"/76.4" —
with 8' box
76.2"/75.8" 75.9"/76.7" — —
B. Overall width
excluding mirrors
78.9" 78.9" 78.9" 86.3"
including mirrors
97.0" 97.0" 97.0" 97.0"
mirrors folded
83.6" 83.6" 83.6" 83.6"
Old Aug 26, 2009 | 11:41 AM
°°Pat°°'s Avatar
The width comes from the wider lower/upper a-arm. Like after market long travel suspension.
Old Aug 26, 2009 | 01:24 PM
So is only the front wider or did they make the rear axle wider too? Seems too costly to widen the rear, unless they just used spacers. Maybe the front wheels are high offset and the rear low?
If you figure that a standard f150 has 7.5" wide wheels with 5.5" backspacing, then a 9" wide wheel with 4.5" backspacing should stick out 2.5" further than the standard wheel. So there is any easy 5" of width without even considering the wider tires.
