Why not a leveling kit from Ford?
Old Aug 11, 2009 | 10:49 PM
munro200's Avatar
Originally Posted by HotLap
I personally like the look of the leveling kit (2") on the F-150 and contrary to what's been said above a (properly installed) 2" leveling kit does not affect the ride or result in extra wear on the front end suspension. My brother had this done a while back on his '05 Lariat and I have driven it several times...only difference is it sits higher in the front - which is a great feeling! Many have been adding the 2" leveling kits for years with no issues....now get into to 6" lifts with larger wheels and tires and that will change the driving dynamic and wear on suspension components...but just a 2" leveling kit isn't going to hurt your truck
As for hauling heavy loads, I think a heavy load is going to make your headlights shine higher up regardless (since the headlights are aimed with the truck empty from the factory - trick would be to have them re-aimed after the leveling kit has been installed)...but who really hauls heavy loads all the time at night?
Im not saying the 2" leveling kit dosent look good, I have one on my truck but you dont think adding the spacers to a 4x4 puts a little added stress on the cv shafts? They are at a steeper angle, I know my boots on mine are worn more now because of the lift.
Old Aug 11, 2009 | 11:01 PM
MOford21's Avatar
Saying that a leveling kit doesn't add stress to your front suspension is ridiculous. Look at ball joints, CV shaft angles, and control arms compared to stock.
Suspension lifts are less stressful to your front susp. because they keep angles much closer to stock than a leveling kit.
Old Aug 12, 2009 | 01:09 AM
Deano-FX4's Avatar
aero dynamics plain and simple to maximize air flow over the truck in the most efficient way is to have some rake in the front. when you level the front end the windshield acts more like wall. and it maybe only 1-2 mpg but it still a gain in fuel economy.
Old Aug 12, 2009 | 09:19 AM
fordmantpw's Avatar
Originally Posted by Tbird69
X2
Funny thing is my F150 with my 6K lb camper on the hitch still sits higher in the back then my buddy's Sierra unloaded.
My '05 sits pretty level with my 6k lb camper on it. Looks mighty fine I think. Personally, I don't like the open front wheel wells after a leveling kit has been added.
Actually, bringing the front end up to level brings the angle of the windshield back making it more aerodynamic. Any fuel economy gain though would be negated by the higher front end and more upright grill.
Old Aug 12, 2009 | 10:44 AM
Deano-FX4's Avatar
well no it doesn't watch the guy who was in charge of it explain
http://www.youtube.com/watch?v=UagXvoLuWSM
so then what would move through the air more easily, a sheet of plywood standing straight up or a sheet of plywood held at a angle?
Old Aug 12, 2009 | 11:09 AM
fordmantpw's Avatar
I may have missed it, but he didn't say anything about the height of the back of the truck relative to the front.
That's obvious.
But if the windshield is at a (just picking numbers here) 45 degree angle relative to level ground. You raise the front of the truck (level it), that windshield is now at a 43 degree angle to level ground. That makes the wind flow over the windshiled of the leveled truck better, no? The grille and front of the truck is another story though. The more you raise the front of the truck, the closer the windshield gets to laying flat (like the plywood you mentioned).
Hold your hands flat, with one being the truck and one being the windshield like this:
Now, tilt the left side of your hand up a little. What happens to the windshield? It lays back.
Old Aug 12, 2009 | 11:43 AM
yetti96's Avatar
I highly doubt the rake is for aero, so I propose we kill that topic right here and now before it turns into a synthetic vs dino oil interval battle. Ford did it for a reason, but I agree it doesn't look good. Exactly why I leveled mine 2.5"
Old Aug 12, 2009 | 11:53 AM
GreenBuck50's Avatar
I just drive it and use it... I don't care if it is level.
Old Aug 12, 2009 | 12:26 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Originally Posted by newmandl
...why does Ford make their trucks so that it is required to install a leveling kit? Why not create the truck with it already “level”?...
Because if they did....
GM, Dodge and everybody else would hook a trailer to the OEM factory Ford or put a few rocks in the bed...
...and then they would make a TV commercial....and laugh all the way to the bank.
Old Aug 12, 2009 | 01:10 PM
Tbird69's Avatar
It was done for one simple reason, I've already said it but I'll say it again. The F150 was built with a forward rake so when it gets loaded down it sits level, that's it. This maintains handling, steering and keeps the headlights from pointing at the stars.
In my opinion, the leveled trucks are the ones that don't look good.
Old Aug 12, 2009 | 02:30 PM
sterling09FX4's Avatar
to each his own...!!
Old Aug 12, 2009 | 03:33 PM
yetti96's Avatar
It was done for one simple reason, I've already said it but I'll say it again. The F150 was built with a forward rake so when it gets loaded down it sits level, that's it. This maintains handling, steering and keeps the headlights from pointing at the stars....
I agree with that much. Here are my pictures. The 3rd pic of of my leveled truck sitting in my front yard. I know it is kind of minor for most, but my truck could not get across my front yard ditch as pictured before I was leveled. I use my yard as a work area so I can get under the truck and work it for whatever, much more room and safer than the concrete driveway.
A side note never really mentioned with leveling, when I got the truck I felt as if I was always slamming on the brakes because of how low the nose was. I also had a hard time seeing out the back for little ricers trying to drive up under me. (If it were not for the backup sensors and leveling I would have crushed a few by now.) Rear visibility and feeling of the truck both got better with raising the nose 2.5". The first day or 2 the truck felt so much more athletic and better feeling now that the nose wasn't dragging on the ground.
On to the pictures.
Stock:
Leveled:
Leveled with 1200 lb of water in the bed. A little nose high, but not horrible for technically being over GVWR (7200LB):
Old Aug 12, 2009 | 04:15 PM
newmandl's Avatar
Do you use a wetsuit when working on the truck? Quite a bit of water in the ditch.
Old Aug 12, 2009 | 04:49 PM
yetti96's Avatar
Touche'...I parked it there just to show a friend and took a picture of it. When working on it is is dry and I always end up finishing after dark and can't get a good pic. Thanks though
Old Aug 12, 2009 | 06:14 PM
v_tach's Avatar
Leveled trucks are alright... if you like the look of carrying a load all the time.
