bazooka tube
bazooka tube
Thinking about a bazooka tube in my '09 150 crew. I've had good systems in the past with custom boxes, amps, pre amps, etc.
But I'm just looking for simplicity and I don't feel like sinking too much cash. I love the sync so i'm sticking with the stock head uni. I want good base, but I don't need drug-dealer sound.
I changed the front speakers to eclipse 6.5 inch component speakers and the sound is really good, but now it makes me want more. I'm going to change the rears to a 6x8 set of eclipses and I want a sub, but I don't want to make a huge box under the rear seat because I use the space when I travel.
I'm looking at the 250w 10inch bazooka. They look very easy to install and can be removed, easily. The nice thing about the 250 watt version is that a second passive tube can be chained onto it if I feel that there isn't enough base with just one tube.
Was wondering if anyone has experience with bazooka's quality, power, etc.
But more importantly, will the 10 inch fit under the seat?
Any comments about your experience would be helpful.
I still wanted to keep the use of the flat load floor so i custom made a box so that i could remove it in the same amount of time it takes to remove the standard sub and i made sure that i kept the stock wireing so that i could plug the factory sub back in if i need a little space but still wanted some bass. The connections were all quick disconnects as well. It dont matter what one you go for because you will have to remove any tye of sub if you want full use of the flat load floor so might as well make it worth ya while and do it properly.
