Tranny Studder
Old Jun 3, 2009 | 10:42 PM
Monkey#39's Avatar
Tranny Studder
DOes anyone have a studder problem in Reverse? It feels/sound the same as if you were taking off and had rear end hop(but thats not it )
If i shift from D to R and then give it gas it does this. doesn't happen all the time and sometimes happens even if a wait 4-5secs then hit the gas...?
Old Jun 3, 2009 | 10:55 PM
BIG_ole_TRUCK's Avatar
I know of the problem you wrote. A Plat I was interested in buying suffered the same problem. It seemed the engine spun freely for a second or two and then slammed into reverse with the feeling the rear end wanted to lift. The jerking was too severe for comfort.
Althought it feels like a mechanical problem, try the transmission re-flash (TSB) and see if it solves the problem.
Old Jun 4, 2009 | 04:48 AM
SportTractoF150's Avatar
yea my platinum kind of displays this issue. i thought it was maybe from driveshaft angles from my lift tho
Old Jun 4, 2009 | 04:13 PM
HotLap's Avatar
Mine just did it for the 1st time the other day...wasn't severe but I did feel the shudder when I shifted from Park to Reverse and gave it gas....
Old Jun 4, 2009 | 08:10 PM
Gotmy09's Avatar
Mine has done the same thing a couple of times. I've learned to just give it an extra second when putting in reverse to make sure it's engaged. Seems like an ever so slight to delay after you shift to R.
Old Jun 4, 2009 | 09:03 PM
bigmojo's Avatar
same here in my plat. I just give it a second before I step on it. Hope the TSB will address it.
Old Jun 4, 2009 | 09:06 PM
does it do it cold or hot or both?
Old Jun 5, 2009 | 02:26 PM
bigmojo's Avatar
Both.
Old Jun 6, 2009 | 02:29 AM
Monkey#39's Avatar
yup hot and cold... Glad I'm not the only one
