Question about factory sub?
Old May 22, 2009 | 01:02 AM
Pcaman's Avatar
Has anybody tried just replacing the stock amp and sub, but keeping the stock box. I would think that that would solve the problem of the bass level cutting out at higher volumes. Any thoughts?
Old May 22, 2009 | 08:45 AM
Barritia's Avatar
I did read on one forum that some guy tried this but he had a problem with the sub wireing as it was a dual coil. You could get around that by upgradeing the amp but then you would need to upgrade the wireing from the batterey to the new amp. Plus the amp on the fatory sub is so small i think you would be lucky to find anything that would fit and give out as more power. Also the amp uses a 6v trigger so you will need to buy a 12v relay switch to get the voltage up higher and hack into the incoming 12v feed.
Old May 23, 2009 | 01:04 AM
Pcaman's Avatar
I meant putting an aftermarket amp somewhere else and just utilizing the stock box with the stock speaker or also upgrading the sub woofer as well.
Old May 27, 2009 | 10:41 PM
Pcaman's Avatar
anybody else have any thoughts?
Old May 27, 2009 | 10:57 PM
Power Kid's Avatar
Sounds good, if someone figures it out. I'd do it.
Old May 27, 2009 | 11:34 PM
markstanco's Avatar
its not cutting out. The stereo lowers the volume when you turn the audio up to higher volumes to protect the speaker.
Simply replacing the sub and/or the box will not remedy this. You need to add something like this to keep the bass signal from being lowered at high levels:
http://www.crutchfield.com/p_236REQ/MTX-re-Q.html
Old May 28, 2009 | 07:35 AM
Barritia's Avatar
It's not the stereo thats lower the signal. It's the amp on the sub. I have upgraded my sub and amp and tested with a meter the levels from the headunit and i had zero drop all the way from 1%-100% volume output. It was steady climb. The Amp must just have a limiting circuit built in so it either don't damage the speaker or pull to much current.
