The three holes...
Old May 11, 2009 | 08:18 AM
BrainDonor's Avatar
Originally Posted by SportTractoF150
Why would you want a bed extender that doesn't swivel? That would mean it's either permanently inside the bed (so no real extension to the bed length), or permanently outside the bed (so your tailgate is always down and you will never have any security of your cargo).
At least those are my observations.
It's not permanent. It's going to be inside the bed 98% of the time. It's easy to lift it out of the slots and flip it over. Not too much of an inconvenience. I've got it put together, but the M10 bolts I bought for the mounting brackets aren't cooperating, so I am rethinking the mount. Plus, the Line-X spray-in bedliner was sprayed into those holes. So, I may need to get a smaller bolt and pop off the tail lights and put a nut on the other side.
Old May 12, 2009 | 11:46 PM
vjhpac's Avatar
Did you get any pics?
Old May 13, 2009 | 07:46 AM
BrainDonor's Avatar
Yes...but I'm not ready to share just yet. The bolts I bought are interfering with the extender...I need to get a couple of panhead bolts since they have a flat top. I ended up having to pop the tail lights out and put a nut on the inside of the sidewall. Not a big deal, two screws are all that had to come out and the tail lights pulled right out.
Old May 14, 2009 | 08:53 PM
BrainDonor's Avatar
I HATE cheap plastic parts.
I have the mounting brackets on...but one of the plastic pieces that go into the bracket sheared right off. So, I am going to rethink this a bit. I'll get there, it'll just take a bit of ingenuity.
*puts on thinking cap*
Old May 17, 2009 | 02:21 PM
BrainDonor's Avatar
Okay...I got installed. I used 3/16" x 2" eye bolts inserted into 5/16" aluminum spacers to work as my pivot.
I removed the tail lights and used a locking nut to hold the spacer to the eye bolt.
On the bed extender itself, I drilled through the center hole where the self-taping screws are supposed to go. Through that I inserted a 3/16" x 3" eye bolt and fastened it with a locking nut.
I put a quick release clasp through both eye bolts to hold it together. It now pivots, whereas before it wouldn't.
Couple of things I need to consider...the eye bolts are zinc plated...I am looking for stainless so they don't corrode. Also, I need a different clasp to hold these the eye bolts together I think...the one I used is kind of loose fitting. I'm also thinking about replacing the 2" eye bolts with a 1"...the 2's are a bit too long. Anyway, here are the pics...
The hardware:
Tail light off and aluminum spacer and eye bolt installed:
Tail light back on:
Bed extender with center hole drilled out and eye bolt installed:
Eye bolts held together with quick release clasp:
Bed extender in the bed:
Bed extender out of the bed on tailgate:
Bed extender mid-pivot:
Old May 17, 2009 | 06:47 PM
broncobran68's Avatar
Your bed extender looks much more useful than my stock one. The factory one isn't very big because they cut the corners to make it more rigid. I like your setup but I would try come up with a better mounting system. Although given the setup I can't really come up with a better idea.
Old May 17, 2009 | 07:46 PM
BrainDonor's Avatar
Thanks. Yeah, that was my biggest problem. I wanted to utilize the existing hole(s) and not have to drill the truck. I know it's not that big of a deal, I just didn't want to do it.
This mounting system will work for now, but I am still going to noodle on it some more.
