Spray liner in and fork clamps on
Old Apr 9, 2009 | 11:18 AM
BIG_ole_TRUCK's Avatar
nice!
Old Jul 24, 2009 | 01:16 PM
HoosierRealtor's Avatar
Originally Posted by Barritia
I done mine by bolting it to the bed, but it was not very easy. I had to fit some blind nuts/rivet nuts. Because getting behind the bed was impossible. Let me know if you need some more detailed pics.
I would love to know how you did this, I want to do the same, but I am not sure about "blind nuts/rivet nuts" any help would be greatly appreciated.
Thanks,
Brian
Old Jul 24, 2009 | 03:36 PM
Barritia's Avatar
Hey brian. These are what the blind rivet nuts look like. You should be able to get them from any good industrial fixings store or online. the ones i used look like the first photo.
You drill a hole and then they work like a normal rivet but you would normally need a special tool.
I had to improvise here because i didnt want to buy a tool for this for just 4 rivet nuts. what i did was get a long bolt that would fit the rivet nut and then added a nut that was the size to fit that bolt and wound this all the way on the bolt. I then added numerous washers to build them up so that i could insert the bolt into the rivet nut then tighten down the nut that was on the bolt and in turn would tighten the rivet nut as i done up the nut on the bolt. Hope this makes some sense. If not let me know and i will go build one up quicly to give you an idea.
Or you could just do it the easy way and remove the bed bolts and slide the bed back a bit and then bolt your fork clamps on.
Old Jul 24, 2009 | 03:51 PM
IORf150's Avatar
Looks real good man, I too have been thinking about getting the line-x for my truck.
Old Jul 24, 2009 | 04:31 PM
4x4wolf's Avatar
Nice looking plat., bed looks really good
Old Aug 8, 2010 | 01:16 PM
kelley350x's Avatar
Ohh and i found out what the pastic caps were for at the front of the bed. They used to be there for when people put camper things into the back of the bed so that all the cables and stuff could be routed to the bed. Crazy thing is They are still in the truck beds even though the bed campers are very rare now.
Now they are used to run wires through if your going to install a diesel tank with a fuel transfer pump.
Old Aug 18, 2010 | 03:23 PM
2manytoyz1's Avatar
Looks good! I have an appointment tomorrow morning to get my truck bed & tailgate sprayed. Local price quoted is $499, and they offer either a $20 or $50 discount, depending on timing.
I'll take a look at the clearance issue you mentioned, and be sure to point that out rather than finding out the hard way!
Thanks for posting the info!
