Crew Cab space behind rear seat?
Old Mar 25, 2009 | 10:31 AM
BigZAJ's Avatar
I know that when you fold up the rear seat the backrest falls backwards down into the cavity behind the seat. Does anyone know if there is enough space behind the seat for an amplifier, if mounted down low on the wall. Thanks.
Old Mar 25, 2009 | 10:43 AM
achap's Avatar
i havent seen them, but im sure there is. I have my amps mounted behind the rear seat of my 07, as do many people. So im pretty sure there will be room. Now may how much room someone could chime in...room enough for 2 TW5's?
Old Mar 25, 2009 | 11:04 AM
BigZAJ's Avatar
How do those sound, I have yet to hear them? I was thinking enough for JL HD amps so I can throw 2 8w7s under the seat.
Old Mar 25, 2009 | 11:12 AM
cdiddy4224's Avatar
I have an 09, and i have 2 amps mounted on the back wall. So, to answer your question there is enough space!
Old Mar 25, 2009 | 11:18 AM
blk03ltng's Avatar
I too will be mounting an amp on the back wall.
Diddy, can you shed some light on the quickest way to disassemble the back seat and the door panels?
Old Mar 25, 2009 | 12:01 PM
sandydiego's Avatar
Can you post some photos of your install?
Old Mar 25, 2009 | 01:53 PM
cdiddy4224's Avatar
the best way to access the back panel is to unbolt the back seats from the floor. It takes a bit to get all the bolts out, but once you have those out, the seats should slide right out. Without looking, i believe there are about 8 bolts that hold those seats down.
Cant help you on the door panels...
As far as pics of the install, id have to unbolt the seats which is a PTA. I didnt have the installer take any pics but i saw when the truck was apart how they were mounted on the back wall.
Old Mar 25, 2009 | 02:02 PM
pmason718's Avatar
I have mine on my back seat also but when I but my back seat on the seat cushion is touching the amps.
Old Mar 25, 2009 | 07:13 PM
blk03ltng's Avatar
Thanks for the info.
Old Mar 27, 2009 | 10:16 AM
blk03ltng's Avatar
For Crew cab rear seat removal..
http://www.justanswer.com/uploads/pr...14_40_seat.pdf
found this page
http://www.justanswer.com/uploads/pr...20_60_seat.pdf
and this one for the other side.
Old Mar 27, 2009 | 10:30 AM
sandydiego's Avatar
Great! Thanks for the link to the PDF's
Steve
Old Mar 27, 2009 | 04:23 PM
CobyMedic's Avatar
looks a little easier then the 04-08 those things were horrible removing the first time.
Those PDFs will come in very handy for alot of people.
Old Mar 27, 2009 | 05:26 PM
sandydiego's Avatar
found this page
Do you have any other 09 pdf's handy? Brakes, Dash, Doors?
Thanks again
Steve
Old Apr 12, 2009 | 06:58 PM
roberto232's Avatar
PDF's like that will come in handy......Thanks
Old Oct 17, 2009 | 02:35 PM
mikemac2010's Avatar
Rear seat removal (40)
I downloaded the pdf's for removal of rear seat in 2009 F150.
However, I cannot get the backrest latch to release! Won't budge. Not sure what I'm doing wrong... I was able to release the 4 bolts that mount the seat to the floor of the cab, in hopes it would loosen the entire assembly, making the seat backrest latch easier to release. Nope. The instructions are excellent, but neither of my rear backrest latches will release. Holding firm.
Any suggestions much appreciated!
MikeMac
