Platinum remote starter
Barrittia and some other owners. So what is the REAL verdict on the remote start in Platinums. If installed does the factory alarm and or code jumping have to be disabled or not. I 'm getting ready the to pull trigger on ordering a new Platinum and waiting to see what my dealer says. In on going discussions they had said yes and no. I want to get a good answer from them. Will still order truck, just want to know.
If yes, what is the key fob issues ( one or two or what). I know I'm beating this to death, but have not seen an answer that makes you believe.
Thanks!
Thanks!
Not owner of platinum but as far as i have heard YES you can do remote start with alarm and everything.
The remote start will REQUIRE a seperate key fob. 1 for remote start. 1 for unlock/lock/alarm. and your truck key. The other option is get a fusion key and that will integrate your key and fob into one so you only have 2 things on your ring. The key and remote start fob.
Thanks!
Thanks!
i don't install Ford remote start systems, we only install compustar 9000 pro remote starts. and the company that builds the transponder override kits now have it built into the their kits through a software update to disarm the alarm. if you guys lived here i could do it for you no problem.
