Truck shut off at drive thru.. Dang it
Old Dec 18, 2023 | 01:05 PM
aqua-holic's Avatar
Hi all,
I have a 07 F150 5.4 2wd with193k that I maintain very well. purrs like a kitten.
Truck was about 15 mins warm when I went to the drive up came to a stop and it shut off. First time for this.
Put it in N and she fired right up (??) I don’t have any engine lights showing.
Will a code reader from Auto Zone still see something happened with no light ?
All regular maintainance item done with fords parts.
3 rd set of ford plugs 10k ago
2nd set of ford coils with plugs change
FPDM done about 5 years ago
fuel filter last year maybe sooner
recent battery and starter 2 months ago
cam and crank sensors couple yrs ago
Ford 5w20 with ford filter every 3000-3500
Cleaned Throttle body 3-4 yrs ago
i have yet to do the fuel injectors because I never had any issues. Should I do them with 193k?
It sucks knowing it’s not dependable right now.
Old Dec 18, 2023 | 04:44 PM
Would not hurt to throw a couple bottles of Techron in the gas. Could possibly be the FPDM or dirty throttle body. Maybe a dirty MAF?
I doubt an Autozone code reader would help unless it can read pending codes.
Old Dec 28, 2023 | 10:23 AM
Ryan2KRedL's Avatar
Check fuel pressure. Possible the fuel pump is failing (low pressure will make truck shut off).
May start out OK when cold, but once pump gets warm/hot it can start dropping pressure.
Good luck!
