2006 f150 starter problem s
Old Feb 8, 2023 | 12:39 PM
Ceecee12's Avatar
The starter on my 2006 ford f150 is clanking off the flywheel when I turn the key, the engine isnt locked up. When they starter is off tranny housing it engages and works properly
Old Feb 9, 2023 | 12:35 PM
getterdun's Avatar
Starter mounting bolt sheared off, missing, loose? Photos showing starter at rest and then after you try to crank it could help.
Old Feb 9, 2023 | 05:29 PM
Roadie's Avatar
Inspect the teeth on the flywheel/flexplate and if they are okay, you might need a new starter.
