5.4l with bank 2 misfires and no codes
Old Sep 11, 2022 | 01:24 PM
projectSHO89's Avatar
Regarding PATS:
would the dealership not be able to pull PATS info from mine and flash into (new to me) different PCM
No, that's not possible.
You have to have two unique PATS keys, already cut. and then reprogram PATS from scratch when swapping out the PCM. You can DIY this with Forscan. IDS, of course, also works.
Old Feb 3, 2023 | 10:09 PM
ripcity3200's Avatar
Bank 2 misfires and no codes
Have you checked the roller followers and cam lobes for defects? Hope you got her fixed by now but I woke up one day about 8 months ago and decided to take a large chunk of my quality of life away and go buy another Ford one morning.
I could probably pass as a master ASE mechanic regarding the timing kit replacements on the 5.4’s from all the literature I’ve read online. Other than the oil pump which you replaced, Ive read that faulty roller followers can issue similar symptoms as timing. Seems like you’ve flashed pcm, checked all vacuum for leaks, swapped coils, plugs, etc. If timing is correct, then possibly a defect in the cam lobe ? The roller followers have had issues breaking or springs loosing tension. GL
Old Feb 13, 2023 | 06:19 PM
getterdun's Avatar
Post deleted.
Old Mar 9, 2023 | 04:22 AM
scottsneed's Avatar
i have the same issue. any updates? debating replacing all the coils here and the phasers. I see that you did the phasers/timing.
Old Feb 13, 2025 | 09:55 AM
daletech26's Avatar
Hey, did you ever figure this one out? I have the exact same problem on a 2007 Expedition that has me stumped.
Old Feb 14, 2025 | 12:25 PM
tgallyg's Avatar
OK so I forgot to update this post on my final "fix". After all the chasing explained above, I cut the cats out of it and patched in straight piping and have been running it ever since without issue. The engine runs very well with the new front end and oil pump. I am somewhat troubled by my lack of troubleshooting prowess but can chalk it up to life long learning. I still need to complete the oxygen sensor patch to eliminate the CEL but the erratic misfires on the one bank are gone.
My apologies for the gap in concluding this post out.
Thanks so much for the guidance provided! Love the forums!
Old Feb 14, 2025 | 08:33 PM
You could put a pair of high flow cats in to keep it legal.
Old Feb 20, 2025 | 11:48 PM
Fifty150's Avatar
It all depends on where you live. In some places, where there are strict inspection standards, deleting the catalytic converters is not acceptable. In some places, high flow catalytic converters are not acceptable. Where I live, catalytic converters must have a registered "executive order" number. Which means that I have to use an extremely expensive catalytic converter.
