Wheel bearing hub replacement
Hello all, just purchased an 06 f150 lariat sight unseen with more problems that I was hoping for.
need to replace the front wheel bearing hub assemblies but for the life of me, I can’t seem to find one that fits the rwd. Searched everywhere, learned the best aftermarket brands (motorcraft, timken, moog…) but can’t find a part number that fits anywhere.
Is it the same as for the 4WD? Can anyone help with a part number?
Got P/N https://www.rockauto.com/en/moreinfo.php?pk=1322172&cc=1431304&pt=1672
RWD F150s have a one piece hub and brake rotor. The 4wd uses a separate hub and rotor. Many replace the rwd one piece unit with kits to make them 2 piece so the rotors can be changed without replacing the hub. I did this on the 04 I had and used a kit by Centric. Sorry, it was a while ago and I don't remember the part numbers.
Centric 2 piece hub and rotor kit:
https://www.rockauto.com/en/moreinfo...=1030&jsn=1030
Requires new spindle nut:
https://www.rockauto.com/en/moreinfo...1400&jsn=11115
Replace the pads. Spindle nut torque is 295 ft/lb (yes, this is not a typo). If you ever have to replace the rotors again, get 4wd rotors.
