5 beeps from dash area
Old Jan 30, 2021 | 12:48 PM
Beermer Burner's Avatar
2007 f150, 5.4, 2wd auto.
Last week a beep was produced coming from the dash near the radio.
It beeps 5 times, pauses then beeps 5 more times for a total of 5 sets of 5 beeps.
Does anyone know that this means, other than the self destruct button was engaged?
TY
Matt
Old Jan 30, 2021 | 12:53 PM
Replace the airbag warning light in the cluster and the beeping will go away. Now, with a primary warning indicator that works, you can count the flashes to get a two-digit Lamp Fault Code (LFC) that will guide you towards diagnosing the fault in the airbag system, if there any more issues.
Old Jan 30, 2021 | 12:57 PM
projectSHO89's Avatar
FWIW, the indicator in an 07's cluster is probably a surface-mounted LED rather than a simple light bulb.
Old Feb 2, 2021 | 07:29 PM
THANK YOU for the quick reply.
OK, so you are saying the light that is above the radio area on the center of the dashboard?
Matt
