help with starting problems
Old Oct 6, 2020 | 03:04 PM
Duane Hartman's Avatar
I have a 2004 ford f150 heritage and I'm having a starting problem. When i go to start the truck i have to turn the key to the on position, wait 30-45 seconds before turning it over for it to start. If i don't do this process it will turn over but not fire. when i turn the key to the on position I can hear the fuel pump kick in so I don't think it is a fuel pump problem. when it starts it runs great. Any help on what to look for would be great.
Thank you
Old Oct 6, 2020 | 03:08 PM
When was the last time you changed the fuel filter?
Go to a parts store, borrow/rent a fuel pressure gauge, connect it, turn on the key, and read the pressure. 28 psi minimum required to start.
Will it start if you give it a little gas? Hold the pedal to the floor?
Old Oct 6, 2020 | 07:15 PM
will not start if i give it gas or pump the gas. only when i wait 30-45 seconds
Old Oct 6, 2020 | 08:03 PM
What about holding it to the floor? Pumping does nothing whatsoever, it's not a carburetor. Cracking it open will compensate for a stuck closed idle air controller. Holding it to the floor shuts the injectors off to clear a flooded engine.
So, what about the fuel filter? Should be changed every 30k. Check the fuel pressure.
