Engine/Tranny surges,slips
Old Sep 28, 2020 | 07:57 PM
mkinttrim's Avatar
Lately I noticed that I get a mild surge or slip in the tranny especially going up a grade and between 4th and overdrive. Its NOT shaking or violent by any means and if I floor it it goes away. I've read in the tranny forum that it could be a COP or plug but just had plugs replaced last fall and I've only put 8K since then. COPS have never been replaced though. It does not throw a code either.
I'm original owner with almost 150K miles, transmission fluid changed every 60K. Any ideas? Thanks
Old Sep 29, 2020 | 06:33 PM
Booshockaya's Avatar
Unfortunately could be many things. I was having a similar issue and mine was Cam Phasers. given your mileage that could be the issue. The other could be a bad over drive band/overdrive pin with broken C-clip. I would personally check that Cam Phasers are working properly.
Old Sep 29, 2020 | 11:06 PM
I'd lean more toward cops.
