2007 F150 Numeric Keypad problem
Old May 27, 2017 | 07:32 AM
mose56's Avatar
2007 F150 250K Miles Running great looks good
Numeric Key Pad quit working. When I depress each individual button one at a time they all light up except the 1-2 button. The factory code and my personal code both contain a #1. Naturally if 1-2 don't light up I assume that button is the problem. I understand how to remove the key pad. Is it possible that the 1-2 button can be repaired/cleaned and made to function again? From what I have found a new key pad cost + - $ 50.00. mose56 in Phoenix
Old May 28, 2017 | 08:39 PM
05RedFX4's Avatar
The 10-12 fusions had the same pad setup and one of the buttons quit lighting up on my 11, but the button still worked. The light is just that, a light. It does not tie in with the function of the button. Try it and see if yours still works.
You could always change your personal code to not include the 1/2 button, if it bothers you that much.
AFAIK, the keypad module is not serviceable and only comes as a complete unit.
Old May 29, 2017 | 11:26 AM
mose56's Avatar
Thumbs down Numeric Entry Key Pad
That is the problem. The 1-2 button is a part of the Mfg. Code and a part of my Personal Code. It does not work, I am unable to activate the lock or unlock with either code, idiicating it does not work. Hence the Light does not go on when you depress it.
Old May 29, 2017 | 11:18 PM
05RedFX4's Avatar
Well it sounds like you need a new keypad then. On the fusion I had when you press any button, all 5 would light up, until the one light burned out. On yours if you press another button do the rest still light up?
Old May 30, 2017 | 10:15 AM
mose56's Avatar
When you depress the (1-2) button none of the other buttons light up including the (1-2) button. When you depress any of the other buttons (3-4), (5-6), (7-8) and (9-0) individually they all light up including the (1-2) button. Again the Mfg Code and my personal code include a 1 therefor I am unable to unlock with the Mfg Code, my Personal Code or change my Personal code. I think at this point I am going to remove the Button Assy. temporarly cover the opening, and spend a little time getting a little deeper into the inside of the (1-2) button. Thanks mose56
