Truck idle surges and dies out.
Old Feb 9, 2017 | 11:13 PM
NKY05's Avatar
05 F150 5.4L 3v
I just changed COPs and plugs, cleaned the MAF and throttle body, changed fuel and air filter, and check valve. When I fire up the truck the engine, the engine runs up to about 1500rpm and then goes to a normal idle and after about a minute the idle starts to fluctuate from normal to about 450-500rpm a couple of times and then the engine dies out. Who has a clue as to what's going on? Also, Crank Position Sensor has been changed. This is frustrating.
Old Feb 18, 2017 | 01:46 PM
dont slow down's Avatar
Did you clean your throttle position sensor when you cleaned the throttle body?
