How does this happen!!!!!!
I'm new so take it easy on me. Was wanting to know what would cause this to happen and do I need to replace. I actually just replaced plugs and afterwards got a rough idle and low rpm. I have double and triple checked everything and can find nothing. Would this cause my problem? It's an 2004 f 150 4.6
What shows is just casting flash. Not a crack unless it does not show in the photo.
171/174 is an vacuum leak that has shifted the long term fuel tables for both banks.
Code 208 is likely an injector connector not seated since you just worked on those areas.
Good luck.
Good luck.
