06 Lariat Instrument Cluster Lens
Old Mar 5, 2016 | 10:47 PM
Matticus06's Avatar
Hey fellas.. I'm trying to replace the plastic lens for my instrument cluster as the previous owner was a smoker and left a nasty burn mark on it . Does anyone know where I can find a part number for just the plastic lens? Anyone have experience or suggestion on replacing one too? Thanks for your time!
-Matt
Old Mar 6, 2016 | 09:26 AM
2008_XL's Avatar
-Matt
You might want to check and see if the clear screen is the same for all models of clusters. If so, I bet you could find one on eBay.
How would someone burn the instrument cluster while smoking? That's crazy.
I don't think I'd be able to buy a vehicle that was smoked in. They're disgusting, no offense.
Old Mar 6, 2016 | 11:24 AM
Matticus06's Avatar
I did think about the possibility that all the plastic lens covers were identical, just wasn't certain. I'll check ebay and some local pick-n-pulls for sure. I could have sworn there was a post around here that had part numbers for every piece you could think of regarding these trucks, if I recall correctly it had to do with collision-repair pdf….
As far as the smoking part, I too am disgusted by it. If this truck smelled utterly gross or looked like it was neglected in that way I would have passed. Surprisingly the instrument cluster is the worst part.
Old Mar 6, 2016 | 11:27 AM
2008_XL's Avatar
Glad to hear it's not terrible inside!
Thinking about it, the lower end clusters have a long button that sticks out to reset the trip odometer and the higher end models are controlled on the wheel.
Sorry I'm not able to give you the exact info you're looking for. Hopefully someone else will chime in.
Old Mar 6, 2016 | 04:17 PM
EBC-150's Avatar
No, they are different, as the chrome gauge surrounds are built into the cover. The part you need is 4L3Z-10890-CA
Old Mar 6, 2016 | 04:23 PM
2008_XL's Avatar
The gauge surrounds do not appear to be build into the plastic lense.
Looks to be the same cover on my old broken xl cluster that easily snaps on and off.
Edit: after some research, I think he's right:
Old Mar 6, 2016 | 05:03 PM
Matticus06's Avatar
Perfect. That part number seems to be exactly what I am looking for.
Thanks for all the replies fellas!
