Injector codes after plug change!!!??
Old Dec 19, 2015 | 10:03 PM
Bw88350's Avatar
Hey guys...2nd post...great forum!!... So, my 2007 FX4 5.4 had 2 misfire Codes #1, #8. So I changed all 8 plugs (motorcraft) and coils. Started up and ran really rough, smelled like rotten eggs/sulfur. Almost no acceleration! Now I have codes P0201, P0202, P0203, P0204, P0205, P0352, P0355 and P0358... The last 3 are likely from me trying couls coils on other cylinders... My question Is the inj codes. Could 5 injectors all go at once? Doesn't seem like a pcm issue as its not all cylinders and/or only 1 bank. Nxt step ohm testing the suspect injectors? What are the chances a full I jector swap would solve my issue? Thanks!!
Old Dec 19, 2015 | 10:19 PM
You must have knocked something loose, didn't replug something completely, or pinched something when you changed the plugs and coils.
Old Dec 19, 2015 | 10:20 PM
Are you sure you hooked up the correct wires back to their corresponding cylinders?
Old Dec 19, 2015 | 10:30 PM
Bw88350's Avatar
I'll triple- re-check all connections, and that I put them in the correct location...I hope it was a brain-fart moment for sure...just odd misfire Codes cleared, but now injector codes pop up. I did forget to un-hook battery, but unplugged pcm, them went oh *#$%, and un hooked batt...coukd that have killed it? Thanks guys
Old Dec 19, 2015 | 10:33 PM
It may have. I don't know how touchy the PCM is.
Old Dec 19, 2015 | 10:35 PM
Bw88350's Avatar
Crap...I'll re-check connections tomorrow, make sure they're in the right spot. Anyway to test the pcm? Thanks
Old Dec 20, 2015 | 08:49 AM
I half way decent method to test the PCM, is by plugging a reader into the OBD port and see what you get for readings or if it will work at all.
Why did you unplug the PCM for a spark plug change? Normally you don't do anything and to clear the codes you should really use a code reader.
Old Dec 20, 2015 | 11:01 AM
Bw88350's Avatar
I used OBD II MX reader, read codes OK...so hopefully not pxm....I unhooked the pcm to get at plug #4, hands are too stubby otherwise lol
Old Dec 21, 2015 | 07:03 PM
Bw88350's Avatar
Update:
So, I cleared codes, re-checked my work, looked over vacum lines best I could...no codes came back, but it still is running horribly! Trying to get a cel to trip so I have some direction...I did notice if I unhooked vacum line from driver side solenoid and plugged it, it smoothed idle out
Old Dec 22, 2015 | 10:53 AM
That is telling us you have a vacuum leak.
At this point, I would get a propane torch (not lit, of course), and see where you get idle fluctuations when you get near a vacuum leak with the gas.
Don't use carb cleaner, brake cleaner, etc... it eats them rubber hoses!
Old Dec 22, 2015 | 06:52 PM
Bw88350's Avatar
Thanks! Great idea! Always weary of brake clean/carb cleaner and all that plastic/rubber...I'm gonna give it a shot Thursday... I may replace plugs and/or coils one more time, since in my dark days as a Chevy guy I replaced plugs and chased gremlins for 8 months only to discover I had 2 bad ones! I'll keep updates going... Thanks again
Old Dec 26, 2015 | 05:37 PM
Bw88350's Avatar
Post Christmas update:
So, I went ahead and changed all 8 plugs (motorcraft) with motorcraft...while going over all my previous work, I noticed the coils I had installed (amazon no names) 4 had cracked where the plug connects!!! Seems you guys were right that I should re-check everything!!! Luckily had 5 of my old motorcraft coils, replaced them...cleaned maf, fired up, ran like a new truck! Didn't do re-learn yet, so its got a few stalls at turns etc, but its now 95% better than it was! I am ordering new MOTORCRAFT coils Monday! I hope it has solved my issues, and I'll update in a couple days. Thanks!
Old Dec 26, 2015 | 07:51 PM
Excellent news!
Reminds me of some of the crew's (including mine) 4.2l v6... only likes Motorcraft everything for plugs, wires, and the coil pack. I know it's just the quality and the fact that it is designed for the engine.
Old Dec 26, 2015 | 07:54 PM
I've said this before and will say it again. The only CHEAP coils I recommend are "Araparts". The way you wrote your first post sounds like you used Motorcraft coils, if you had indicated otherwise I would have immediately recommended you get rid of the no names.
Old Dec 26, 2015 | 08:04 PM
Bw88350's Avatar
I appreciate it fellas! I should listen more often! I was the same way with my trans am and "cheaoo" parts, cost me soooo much more than buying once/crying once! I hopefully have learned my lesson....again!!... As a side note, being my first Ford truck, I love it! Switched me pretty easily!
