17" to 18" rim now low pressure sensor wont deactivate
Old Oct 29, 2015 | 12:27 AM
Grifter77's Avatar
Hey guys need some help PLEASE
I changed from the stock 17" ford rims to a set of 18" rims
and now the low tire pressure sensor wont turn off
the stock rims were on my 2007 F150 STX
the 18" rims were from a 2014 F150
from what I read they have the same sensor and they arent low so what do I do to make this stop.
please help its driving me nuts
Old Oct 29, 2015 | 01:01 AM
bro_turtle's Avatar
You would have to take it to ford and have them reset the sensors and synced with the truck since it's a completely different sensor.
Old Oct 29, 2015 | 01:05 AM
Grifter77's Avatar
Is that something I can do my self
Old Oct 29, 2015 | 01:09 AM
bro_turtle's Avatar
As far as I know no. When I had my sensors put on my new rims I had to take it to ford and have them reset the psi since i went from running a 45 psi on stocks to 30 psi on my mudders I had. They did it for me for free. So they shouldn't charge you for it as far as I know.
Old Oct 29, 2015 | 08:19 AM
2008_XL's Avatar
They do not have the same sensors. Your 07 has a band that's wrapped around the inside of the wheel, and the 09+, they're in the valve stems. I'm not sure they're compatible with each other. .
Your best bet is to take the sensors off your 17" wheels and install them on your new wheels with new bands.
Old Oct 29, 2015 | 07:57 PM
Grifter77's Avatar
i seem to have both. i have two tires with bands and two with valve stems.
how can i check compatibility
Old Oct 29, 2015 | 07:59 PM
2008_XL's Avatar
All 4 need to have bands to work correctly with the truck. I do not believe the valve stem style will work on your generation truck.
Old Oct 29, 2015 | 08:02 PM
Grifter77's Avatar
I apologize I didn't clarify myself I took the tires off my old rims and I seem to have bands on two of the tires and valve stem connections on to that's from my memory though I will check tomorrow and take pictures
Old Oct 29, 2015 | 08:04 PM
2008_XL's Avatar
Weird. My 2008 uses bands for all 4 wheels (all 07 and 08's do). 09+ switched to valve stem tpms and I've heard they're not compatible.
If you can get all 4 band style tpms on your new wheels, you won't have a problem. If they're not the ones that came on your truck from the factory, they will need to be relearned though.
Old Nov 1, 2015 | 10:31 AM
meanstreak's Avatar
Same thing happened to my 07, discount tire installed a new battery in one of them for $60
Old Nov 1, 2015 | 11:25 AM
2008_XL's Avatar
Did you end up checking and taking photos?
Old Nov 1, 2015 | 04:13 PM
I want to get another set of rims for my truck, same size (17"), but I need to find exactly what part # is for my truck. Mine's a 2007.
Old Nov 1, 2015 | 04:25 PM
2008_XL's Avatar
http://www.ebay.com/ulk/itm/191114370206
And here's a used set for a lot less: http://www.ebay.com/ulk/itm/272032040751
These are the ones for 2007-2008 F150's. You'd need to have new bands installed too. They're pretty much just huge radiator hose clamps and shouldn't cost more than $10 for all 4. The tpms needs to be mounted 180° from the valve stem. If the valve stem was at 12:00, you'd put the tpms at 6:00.
The tpms you have on your truck are already "learned" to your truck. The new/used ones will not be and you'll need a tire shop to re learn them for you. I **think** there's a do it yourself way where you have to deflate the tires and bit, the horn sounds, then you inflate them. It's a process in which I cannot remember at the moment.
Here's one of the ones from my original stock steel wheels (my new chrome clad are from a 2008 and already had them.)
Old Nov 1, 2015 | 09:00 PM
Tim Myers's Avatar
