pics of new 295/60r20 open country mt's, cv axle recomendations ford or aftermarket?
Old Sep 17, 2015 | 02:13 PM
fivespeedsteed's Avatar
just got 295/60r20 open country mt's mounted on oem 20s i found on ebay.
somehow or another i got a hole in my front right cv boot. ford is 280 a piece, aftermarket around 90. anyone have any experience with either?
Old Sep 20, 2015 | 10:14 PM
Mkbf1501990's Avatar
Sweet truck! How are the tires on the highway?
I don't have any experience with them yet but I'm interested as well. I recently found a ripped cv boot on my front passenger side as well.
Old Sep 21, 2015 | 11:41 AM
atr04screw's Avatar
I like it. Any rubbing with that setup? I think I am going to get the 295/60s when it comes time for a new set on my truck.
As for the cv axles, I think you can get a new boot for it if there is nothing wrong with the axle itself.
Old Sep 22, 2015 | 01:20 PM
tires are doing great. they make a little noise on the highway, but its the quietest mud tire ive ever heard. does not bother me one bit. i do rub the lower control arm at full lock.
does anyone make rack limiters for these trucks?
i broke down and bought ford axles. i still have a clunk coming from somewhere, usually hear it when backing up and turning, like to parallel park. no clue. checked the sway bar to frame mounts and i was able to snug them up some more but its still doing it. gonna put end links on it and see if that helps.
Old Sep 22, 2015 | 04:55 PM
Might be a wild shot but check your lower control arm bolts. I've seen stranger things happen.
Old Nov 4, 2015 | 07:17 PM
it was the lower control arm bolts. how wild is that? the factory lca bolt nuts are nylock nuts and i believe the torque spec is 140 ft lbs. i bought a moog camber kit, that replaces said bolts, and they are not nylock. the instructions said torque to 240-260 ft lbs. i was skeptical since its the same bolt i figured it may break. i figured this out after my alignment got off, wheel wasnt centered anymore. i put the front in the air and went over all bolts.
anyways all the lca bolts were loose, i torqued them to 250 and all is well. good to know for those of you installing camber kits.
Old Nov 4, 2015 | 07:36 PM
I missed this post. Nice looking tires! I went with Nittos because Toyo didn't have the 295/60s out at the time. I think they put them out shortly before I had the Nittos mounted. I have had both M/Ts and love them both equally. The Nitto has a chunky mean looking tread and the Toyo side wall is my favorite in terms of applying tire protectant. The Nitto is a S.O.B.
My steering wheel is slightly off center too. I have it aligned with an amateur alignment I did in my garage after I replaced the tie rod ends, been wearing alright but the slight steering wheel issue bugs the heck out of me.
Old Nov 4, 2015 | 08:05 PM
Same thing happened to me when I put ball joints on and remove lca to press the ball joints off and on.
Old Nov 17, 2015 | 07:44 AM
random155's Avatar
i just replaced th whole axle when i got a hole in my cv boot. i bought a $70 one from advanced auto parts and so far no problems. seems like good quality.
