Noise
Old Sep 9, 2015 | 12:24 AM
fsulaxer's Avatar
Noise
So I got new upper and lower control arm ball joints inner and outer tie ride and tie rod ends.....got a funny noise tonight a slight hum click noise not real sure what it is.....engaged 4x4 and disengaged it seems to have stopped it...any ideas what it could be
Old Sep 9, 2015 | 02:58 PM
2008_XL's Avatar
Check out this video.
Old Sep 9, 2015 | 11:04 PM
Doowutchyalike's Avatar
Not sure if it is the video above, or if this link is describing the same thing, but read this thread. My 2005 is doing the same thing, except when I let off the accelerator my noise goes away. So watching the video, I don't think is describing my problem. My sound also goes away when I switch into 4wd
https://www.f150online.com/forums/ar...then-some.html
Old Sep 10, 2015 | 07:44 AM
RevBiker's Avatar
I replaced all of these! They were all leaking. 200K on my truck. 04 F150 STX 4.6 V8 4X4
http://www.ebay.com/itm/Vacuum-Contr...-/251839622032
http://www.ebay.com/itm/NEW-OEM-2004-2008-Ford-F-150-4x4-Vacuum-Line-Tee-Fitting-Check-Valve-Firewall-/251919331043?fits=Model%3AF-150http://www.ebay.com/itm/Fits-Ford-4W...-/230958787448
Old Sep 10, 2015 | 07:46 AM
RevBiker's Avatar
This goes on the vac line coming from the intake!
Vacuum Control Valve-Check Valve MOTORCRAFT YG-360
http://www.ebay.com/itm/Vacuum-Control-Valve-Check-Valve-MOTORCRAFT-YG-360-/251839622032?rmvSB=true
Old Sep 10, 2015 | 07:49 AM
RevBiker's Avatar
You may have a leak in the lines around the parts you just replaced??
http://www.ebay.com/itm/2005-2008-Ford-F-150-4x4-Auto-Hub-Lock-Operating-Vacuum-Tube-Line-Tee-OEM-NEW-/321836190297?fits=Model%3AF-150
Old Oct 18, 2015 | 04:37 PM
RevBiker, I replaced the vacuum line and the vacuum tubes and it fixed my problem!! You saved me a couple hundred bucks!! Thanks for the post.
Old Oct 19, 2015 | 07:16 PM
brianm1a's Avatar
Yeah, just ordered this too. Just replaced the other Check valve (yg360) I'm ready to shoot the first Ford engineer I see. It is maddening sheer and utter madness! If it does not work then on to the entire vacuum harness; as I installed ANOTHER solenoid and IWE's. The symptoms only appear when a load is put on the engine!
Old Oct 22, 2015 | 09:05 AM
Lewissa81's Avatar
I think you should do some trouble shooting before replacing parts. Get a vacuum pump with a guage, and follow the steps in this thread.
http://www.f150forum.com/f72/how-dia...m-esof-186872/
Old Oct 23, 2015 | 05:09 PM
brianm1a's Avatar
Found the leak
Drivers side. Had to blow into the line to find it. Vacuum pump did not make enough noise to locate it. Strange thing is the vacuum line was inside the protective conduit.
Old Oct 24, 2015 | 12:46 PM
Isn't that amazing. Something good must've gashed that. Yikes.
Look at the gunk it sucked in too.
Old Oct 24, 2015 | 06:35 PM
brianm1a's Avatar
Yeah, the logging roads of the North Maine Woods is tough on all vehicles
