07 f-150 running rough
I have a 2007 F-150 XLT with a 4.6L v8 with 83000 miles and need some help
My truck started running like crap today bad enough where I couldn't tow my boat home had to drive it home with out the boat. There no check engine light on but I did pull a code from my gryphon programer it was P1151 but when I got home and hooked the truck up to my innova 3150 scanner it had no codes. Wtf
I notice the truck doesn't sound the same like there's no power to it.
So I decided to change the fuel filter and check the gas seeing as it started happening a little while after I put gas this morning but that was not the problem gas and filter look good and still has the same problem after the fuel filter change
I tried resetting my truck back to stock setting on the gryphon but still the same thing and now I'm getting a code of P1000 on the gryphon and still no code on the innova also my exhaust smells a little funny. Anyone have any insight ion what could be my problem.
Any way to test the o2 sensor before I go replacing them.
Just baffles me that no check engine light came on.
A leaking intake manifold is a vacuum leak. Take a can of carb spray or starter fluid and with engine idling, lightly spray around vacuum hose connections and intake manifold to head joints. If you have a vacuum leak, you'll hear a change in engine running when that spray get's sucked in.
Is there any chance it could be a coil pack bad but not sending a code.
A friend of mine says it sounds like a could pack not working.
This thing is driving me nuts and I don't think the shop can take it in till next week.
When you "Google" Ford Code P1151 , you get a few different things. Here are some results to look at.
http://www.obd-codes.com/p1151-ford
http://engine-codes.com/p1151_ford.html
http://repairpal.com/have-a-p1151-co...accume-maf-198
Thanks tbear853 I think (and hope) I found the problem looks like the intake manifold is leaking coolant into number 7 and 8 spark plug area. I pulled the coil pack and they where wet on those 2 coil packs and I looked down at the spark plug and its soaked.
I heard that this is a common problem on the 4.6L fords I'm assuming that it's causing the coils packs to miss fire on those 2 cylinders and have a vacuum leak in the intake.
I hope this my problem anyone know what's a good brand intake that won't leak again.
