Please Help
Please Help
I finally got everything done to my truck. It is a 2005 f150 lariat with the 5.4 3 valve. I have just completely rebuilt the motor with all new pistons,cams cam phasers. The cams I used are the Comp Cams MT273LL and the recommend valve springs.I did use the cam phaser lock outs. I went to drive it today and it said transmission failure and went into fail safe mode. I turned around and pulled the codes and they were P0720 check my output speed sensor and sure enough it is broke loose so I will get that ordered. Next code was p0022 timing code which I relate to the lockouts. I also have code p2106 and p2195. Can these codes be related to the output sensor being bad? Sorry for the long post just wanted to get all the info out there.
P2106 is for your throttle actuator. I just fixed that on my buddies 04 by cleaning the throttle body.
P2195 is more or less telling you that your passenger side front O2 sensor is bad.
