2006 F-150 King Ranch Window problems
front passenger window won't operate using passenger swt. driver switch works. replaced both passenger swt and driver swt console with new. no change.rear windows will not operate from door swt but will from drivers master. considered driver master isolation swt as the problem. replaced with new swt. any suggestions?
UPDATE: found broken wire in harness between drivers side door and frame. yellow/ light green stripe.wire supplies power to motor through switch. pull back rubber boot to inspect and repair. appears to be a common issue.
