Will 295's rub on stock 20s with 2.5 level??
Old Feb 9, 2015 | 02:40 PM
sjm5104's Avatar
Question Will 295's rub on stock 20s with 2.5 level??
Hey guys, I am about to take the dive on a 2.5 level and new tires for my 08 screw 4x4. I have done a lot of searching and gotten some conflicting information as to what tire sizes will actually contact the control arm and which don't. I have no problem trimming, but do not feel comfortable with tires that will rub any hardware. I don't currently have the money to get new wheels, so I will be sticking with the OEM 20's. I know a lot of people are recommending the 285/65r20 for this setup (and I think these look good), but I love a wider stance and have seen some guys running 295/65r20 and others with 295/60r20s on stock 20s with levels as well.
My question to you folks is will a 295/65r20 or a 295/60r20 rub the control arms or any other hardware on stock 20s with a 2.5 level on an 08 4x4.
Thanks so so much in advance for your help and input....PICS or other advice would be much appreciated
Old Feb 9, 2015 | 04:23 PM
baticus's Avatar
I'm running 295/65/20 on stock rims with a 2" level. Rubs very minor on the upper control arms. Really only enough to scuff the dirt off. Mind you I don't ever hit full lock when steering anyways.
Old Feb 9, 2015 | 06:23 PM
Dog'em's Avatar
It also depends on the type of tire you are wanting. The large lugs of a mud tire will rub the upper A arm with stock wheels. A lower shoulder A/T should work fine. I've got BFG KO's in a 285/65/20 on a 20x9 rim with 5.9" of backspace and no rubbing at all but there is not much room between the tire and the upper.
Old Feb 9, 2015 | 06:42 PM
sjm5104's Avatar
Dogem, let me first say that your truck looks badass. I love the stance. In terms of tire setup, I don't go in the mud enough to warrant something like trail grapplers, if I was going with 295/60s it would probably be something like pro comp xtreme AT's or Nitto Terra's. I haven't seen anyone running the pro comps yet though.
Old Feb 10, 2015 | 08:05 AM
lakemarykid's Avatar
As dog'em says it depends whether you run MT or AT. From what I read when i was looking to go this route, the AT's do not rub but the lugs on the MT do.
I have 295/60R20 Nitto Trails and I had to run a 1/4" Spacer to clear the upper control arm like he said. I now have 2" Bora Wheel Adapters and I had to trim some of the plastic fender, but that is is. Pictures below and links to threads.
1/4" https://www.f150online.com/forums/wh...-oem-20-s.html
w/ 2" https://www.f150online.com/forums/20...installed.html
-Curtis-
Old Feb 10, 2015 | 08:53 AM
sjm5104's Avatar
Lakemarykid,
That is one beautiful ride you have put together. I love the stance, awesome work. So it seems unclear if anyone on here has tried to do it with 295/60r20 AT's. A quick google search shows options like the terra grapplers, Toyo AT, or pro comp xtreme ATs. I think this would be the ideal setup for me, just don't want to do it unless I know it'll work and be safe.
Old Feb 10, 2015 | 05:03 PM
Dog'em's Avatar
Thank you very much for the compliments. The 295/65 are a 35.1" tall tire compared to a 33.9" tall tire (depending on manufacture's exact measurement) My 285/65 BFG's are 34.6 and I had to do some minor trimming on the front and back of the wheel opening due to minor rubbing at full lock. I am assuming your wheels are OEM 20's ? If I remember correctly they have almost 6" of backspace which is why they will rub the upper control arms with about any type of tire. Seems like anytime you use OEM 20's with a tire wider than a 285 or 11.5" wide you run the risk of rubbing the A-arm. I like lakemarykid also run a 2" spacer/adapter just to make sure they don't rub and if you purchase quality adapters that are hub centric with pressed lugs you won't have any issues, at least I haven't for the past ten years.
