Shudder When Taking Foot Off The Gas
Old Apr 30, 2014 | 06:42 PM
  #46
VTX1800N1's Avatar
Originally Posted by cuffee
Thanks glc! If the weather gets better, I will do it this weekend. It's been raining for the past 2 days in VA.
Donald
Just remember you need the special high temp nickel anti seize, which is not what most auto parts stores carry.
Old Apr 30, 2014 | 11:20 PM
  #47
Old May 1, 2014 | 01:54 PM
  #48
cuffee's Avatar
Thanks VTX1800N1. I just ordered the Permatex 77124 Nickel Anti-Seize Lubricant from Amazon (thanks glc).
Quick Question...How many miles can you go without putting any nickel anti-seize on the shanks?
Thanks,
Donald
Old May 1, 2014 | 02:29 PM
  #49
SoonerTruck's Avatar
Thanks,
Donald
Well, a few thousand miles won't hurt it, but I'd get them out before 10K miles or so. The anti-seize is just to combat carbon build-up which is what breaks the plug when you try to remove it. I hope you don't have bad enough carbon build up after a few thousand miles on new plugs to cause an issue. However, the other issue is that since you put anti-seize on the plug threads, you might have over torqued them or they might be more prone to vibrating loose.
Old May 1, 2014 | 03:53 PM
  #50
My originals came out with none breaking at 65,000. Use gas with a good cleaner or run some Techron additive occasionally. Some claim that the shank on the replacement plugs are slightly smaller but don't know if that is a fact or not.
Old May 2, 2014 | 09:34 AM
  #51
cuffee's Avatar
Thanks SoonerTruck for the information. I don't even drive 10K miles a year. At best, I may drive 7K miles per year.
Have a great weekend,
Donald
Old May 2, 2014 | 09:38 AM
  #52
cuffee's Avatar
So far I changed my spark plugs at 97K and 130K miles. I actually changed them myself at 130K miles. I didn't break any spark plugs and they came out pretty easy. Because of this, I have decided to change my spark plugs and ignition coils yearly.
Thanks,
Donald
