saleen1013's Retrofit
Old Dec 23, 2013 | 12:58 PM
  #151
LonestarROB's Avatar
Originally Posted by saleen1013
Back on topic...I'm working with the idea of adding LEDs inside our OEM tail light housings. It'll probably be this in addition to the halogen bulb, but I'm not sure yet.
Why must you be so mean and keep taking my money!?! Very interested to see how they turn out. Always wanted LED tail lights but they dont make em for flaresides. An LED bulb just isn't bright enough for brake lights.
Old Dec 23, 2013 | 01:09 PM
  #152
How 'bout some Oracle lights?
personally I'd just stick with what TRS has to offer.....I've seen, heard, and read of a lot of horror stories with Oracle halo's.....especially the kits for the camaros and chargers....
Old Dec 23, 2013 | 01:33 PM
  #153
saleen1013's Avatar
Haha, I'm just figuring out some sort of design right now. Never did care for buying aftermarket tail lights. I'll also be able to paint parts of it to make them look like Harley tails without reducing the output. More to come!
Thanks for the info. This set seems to be good from what I can see. They offer a lifetime warranty on their lights, but that's only as good as the company backing it.
As with any halos, there is always a risk of one failing. I would not recommend any surface mounted halos for that reason. If they're behind the shroud, you can simply disconnect them and forget they were there. That's not true with surface mounted halos since they're clearly visible even when off.
It is up to the buyer to decide what they want. I can only give my advice.
Old Dec 23, 2013 | 02:35 PM
  #154
that's good advice....
pretty much Oracle gets them from the same manufacture as TRS does.....I can't find the thread on hidplanet right now....but Oracle seems to be made to a different spec over the TRS ones...that thread showed a side by side camparison of both, but that thread was 2 years ago and everything is different now....
Old Dec 23, 2013 | 02:38 PM
  #155
retrofit the tails with a array board having red leds....forget the bulb an array board will be brighter....imo
link for Raptor's third brake light retrofit>>> http://www.f150nation.com/showthread.php?t=354
Old Dec 24, 2013 | 09:52 PM
  #156
Wyseilmykkar_09's Avatar
Some cutoff shots of the FX-R 3.0 Projectors
Saleen, is this vehicle using 4300K bulbs as well?
Old Dec 24, 2013 | 09:54 PM
  #157
saleen1013's Avatar
This is actually 6000K, but it's 55W, so it gets washed out to more of a 5000K color.
Old Dec 24, 2013 | 10:05 PM
  #158
thelariat02's Avatar
Subscribing to steal ideas for possible future retrofit.
Everything is looking great so far saleen!
Old Dec 24, 2013 | 11:48 PM
  #159
saleen1013's Avatar
Thanks! The end result is definitely worth the time put into it.
Old Dec 29, 2013 | 11:33 PM
  #160
saleen1013's Avatar
Here are some installed shots of the red retrofits!
•New OEM Style Housings
•Morimoto MH1 Projectors
•G37-R Shrouds PTM Red
•Black Reflector Bowl
•PTM Red Turn Signal Bowl
•Red Tinted Side Markers
•Morimoto 3Five Ballasts & 6000K Bulbs
Edit: Added info about the lights.
Old Jan 2, 2014 | 10:16 PM
  #161
saleen1013's Avatar
•Morimoto Mini H1 Projectors
•Reflector Bowls Painted Satin Black
•Gatling Gun 2.0 Shrouds Painted Satin Black
•Amber XBaled Angel Eyes
•Tinted Side Markers (Dark)
•Morimoto 3Five 5000K Bulbs
Old Jan 7, 2014 | 12:57 AM
  #162
Those red ones look pretty sick!
Old Jan 7, 2014 | 07:32 PM
  #163
Pockets's Avatar
Sent you a PM Saleen
Old Jan 7, 2014 | 08:24 PM
  #164
What happened to "I like my crazy pnp HIDs?"
What do you use to seal these back up, Saleen? I may have to crack mine open to take care of an issue.
Old Jan 7, 2014 | 08:59 PM
  #165
MGDfan's Avatar
http://www.napaonline.com/Catalog/Ca...622_0006438159
http://www.theretrofitsource.com/pro...roducts_id=792
