Got Tuneup now throwing codes
Old Jun 17, 2013 | 09:03 PM
runnerbl's Avatar
Hello,
Got a tuneup on my '05 F150 FX4. Done by dealership. Only broke 1 plug. Finally got the use my PHP tunes. Only been driving 20 miles or so before shutting off vehicle. The tuneup was done on Friday and had to make a long trip on Sunday. After 50 miles or so, my check engine light came on, wrench came on, nothing happened when I pushed pedal and then battery light came on. Got vehicle stopped. Put in park, cussed A LOT, then tried to start and it started. Check engine light stayed on. This happened about half dozen times. Got to my destination 285 miles, did my business and started trip home. Check engine light stayed on but it didn't stall on me anymore. Seems like it is still running a little rough (might be in my head). Checked to see what the codes it threw and here is what they were:
P2004
P2105
P2106
P2135
Could the tuneup cause these or is it just a coincidence. Never had any issues till after tuneup. Only problem I was having was a miss when going up hills in overdrive. The new plugs fixed that. Any help is appreciated. Hate to go back to dealer ($425) last trip if something I can do myself.
Thanks,
Brian
Old Jun 18, 2013 | 02:09 AM
Take the tunes out and return it to stock, clear the codes.
If you want to run tunes with that CAI, they must be custom tunes.
Old Jun 18, 2013 | 06:52 AM
runnerbl's Avatar
GLC...they are custom tunes form PHP. They are configured form my CAI and dual exhaust. Any other suggestions. Don't want to take to dealership unless necessary. Could it be the tunes that caused this?
Brian
Old Jun 18, 2013 | 10:35 AM
Maybe, maybe not. You need to return to stock and clear the codes and see.
Old Jun 18, 2013 | 10:50 AM
Do as glc has advised. If it returns, then clean the throttle body and MAF. If it still returns, then I would suspect a faulty Throttle Actuator Control. It can appear to be a bad TAC when you have a dirty throttle body. Happened to me on my 2005
Old Jun 18, 2013 | 06:07 PM
runnerbl's Avatar
Thanks, GLC and Bluejay. Will return to stock and clear the codes and then load the tune again. Cleaned the throttle body and MAF not long ago, 6 months, but not since I got the plugs changed.
Old Jun 18, 2013 | 06:56 PM
Then I suspect the TAC.
Old Jun 18, 2013 | 06:58 PM
runnerbl's Avatar
Is that a dealership type repair? If so, what is the going rate for something like that?
Old Jun 18, 2013 | 07:22 PM
Do a search on it. It's under the dash and fairly easy to do. There should be some discussion and pics.
Old Jun 19, 2013 | 07:24 AM
runnerbl's Avatar
I have done a search for TAC and actuator and can't find anything that describes location/pics. If you know where the topic is would you mind providing me a link? Thanks
Brian
Old Jun 19, 2013 | 10:15 AM
No, do NOT load the tune again - drive it STOCK for a while to see how it runs and whether any codes come back.
