What Is It?
Old Jun 16, 2013 | 03:11 AM
08FX4SC's Avatar
What Is It?
What is this part above my frame rail for? It is loose and wobbles side to side. I'm pretty sure it is one of the vibration noises I hear when I hit a bump.
Old Jun 16, 2013 | 03:22 AM
code58's Avatar
It's one of the assembly line workers lunch pail. He set it on the frame rail after lunch and they dropped the bed on it.
Actually it looks like one of the many "fixes" that manufacturers put on vehicles to correct the problems when the design engineers and development test people drop the ball. (all of them do it more often than you think!) Though I've never seen that particular one, it is probably to deal with a harmonic sound or vibration.
Old Jun 16, 2013 | 12:47 PM
2008_XL's Avatar
No idea. My truck definitely does not have that.
Old Jun 16, 2013 | 01:23 PM
worm5932's Avatar
I got one too, my dad says its for vibration dampening. not sure how, or why, he thinks that.
Old Jun 16, 2013 | 10:32 PM
MTM Ford's Avatar
I've read on here and other forums it's some kind of vibration dampener. It does come loose and cause a clunk when going over bumps. From what I've read most guys just remove it.
Mine doesn't have it so I'm not really sure.
Old Jun 17, 2013 | 12:04 AM
tbear853's Avatar
My '07 FX4 Flareside has that weight over top left rear frame rail, it's rubber mounted (in that the mounting bolts go through rubber bushed holes).
My bed does NOT shake at any speed I've ever seen ......
...... but I recall some guys having bed shake problems and not having that weight ..... so I will keep mine in place.
Old Jun 17, 2013 | 12:40 PM
coyote1664's Avatar
it is a vibration dampener, I have replaced them under warranty before and have even removed them outside of warranty. I never noticed a difference on or off except no more rattle
Old Jun 17, 2013 | 01:16 PM
pethel's Avatar
I just looked mine over real good. It doesn't have one.
Old Jun 19, 2013 | 06:09 PM
08FX4SC's Avatar
So it is not supposed to be loose?
Old Jun 19, 2013 | 06:10 PM
08FX4SC's Avatar
Mine is in the exact same place. I will leave it installed also. Thanks for the info.
