A/C help
I've never worked on a R134 system, but when I used to do R12 systems, I'd go for 30 on the low and 150 on the high, NEVER more than 180. I also used a thermometer in the dash vents and looked for about 40. I miss the old sight glasses - that made it easy, charge till the bubbles stop.
There are actually a few cars that still had sight glasses up till recent years. Don't know if any of those cars still do or not. Did make adding a little pretty easy (when that was still legal).
The 134A #'s are not drastically different. Good luck finding 40 on a '04-up NB. Some people actually report nice cold AC in 'em but i think they'd lie about other things too. LOL I've had acouple of interesting experiences charging cars with electric fans when the fan wasn't operating and one of 'em was a BMW that had a multi blade engine fan but the aux. electric in front of the radiator wasn't working. Talk about soaring pressures!
Got a manifold gauge set, thermometer, and a 12.3 oz can of R134a with UV leak detector.
Started the engine and the low pressure side was 25 PSI with 73° ambient temps. A/C was holding steady @ 50°. High pressure side was 150 PSI. I ended up adding the whole can (total added now is 32.3 oz on a system capacity of 34 oz.
Low side pressure went up to 35 and would go no higher. High side pressure went up to 160 and no higher. Compressor still runs continuously.
It seems I have a substantial leak somewhere once pressures reach those levels, as I've added enough refrigerant now to very nearly recharge the entire system from empty. I'll drive it a day or two and then start looking for the UV dye.
New calipers, pads, and stainless braided brake lines are here. I've just got to find time to work on it now....
UV light and glasses got here. The dye is very visible, glows brightly even with the shop lights on and not using the glasses. I can see it on the low pressure port, which is to be expected because I added it not long ago.
Using the glasses in a dark garage, I found no leaks. My guess is evap core? I would think I should be able to see something from the cab, but??? I haven't driven the truck because of a brake problem, but that's getting solved later this week when I get time. Maybe drive with the A/C for a couple days and check again?
I would drive it then for a few days allowing the system to build higher pressures. If there is nothing in the engine compartment after that I would suspect the evap coil. Stupid question, do you have all your caps on the ports?
Yes. The dye I saw on the low pressure port was confined under the cap, so I hope it was just from the fill.
