Passenger window Wont move up or down
Hey Guys
My passenger side window on my 2007 FX2 Supercrew quit working. Both the master and the passenger switch will not move it up or down. All other windows are working as they should from both the master and their respective switches.
The lock out is not on.
Where should i start?
When you engage the switch, do you hear the motor? If yes, then it's the regulator as mentioned above. There is a How To on changing it in the Articles and How To section. If the motor makes no sound, then probably the switch.
link>>> https://www.f150online.com/forums/ar...placement.html
link>>> https://www.f150online.com/forums/ar...ment-pics.html
link>>> https://www.f150online.com/forums/ar...ow-switch.html
another item...sometimes a wire can break in the loom that goes between the jamb and the door....sometimes the ground
Would it be the same thing for the rear glass window? Mine worked great untill the other day, i don't hear any sound either.
Investigated the wire bundle in the door jam boot and low and behold 3 broken wires.....I think I found the problem.
Thanks everyone
I'm putting my f 150 online sticker on the outer door jam
Thanks everyone
So you can't always go by it being the regulator.
