Front Rotors on an 04 SCrew 4x4
Old Apr 30, 2013 | 12:09 PM
N901's Avatar
Hi All,
Will replacing the front rotors on an 04 SCrew 4x4 be the same (simple) as they were on an 05. My 05 they just pulled right off after the caliper bracket. Is there a center nut on the 04, i see that pop up on google at times when searching?
Rear rotors were a b&%$h on my 05 so i think ill leave the 04's alone.
Thanks in advance!!
Old Apr 30, 2013 | 12:42 PM
03GT04FX4's Avatar
Exactly the same, just remove the caliper brackets. they should pull off.....if not, get a bigger hammer!!!!
Old Apr 30, 2013 | 01:10 PM
N901's Avatar
thanks, was hoping they would be the same.
Old May 1, 2013 | 11:54 AM
mkosu04's Avatar
the nut you see is for the 2WD version. It has an integrated hub in the rotor
