Spark Plug Help!!!
Spark Plug Help!!!
I'm attempting to change the spark plugs in my son's 2005 FX4. I've read the TSB and all the step by step posts. I have the lisle tool and all the other necessary tools. I followed the step by step instructions and the plugs seem to be backing out to the end of the threads with no problem. Only problem is that they won't come all the way out. I've had the same problem with the first two I've tried. They don't appear to be broken, I just can't get them out. I've even tried pulling them out with needle nose pliers and they won't budge. Should I back them out as far as they go and soak them with more carb cleaner?
Well, 6 of the 8 broke. That's after soaking with PB Blaster and Carb Cleaner for about 12 hours. Bluejay was right. The metal electrode was hanging down in the piece of ceramic that was stuck in the head. I had to shoot a little more carb cleaner and let it soak for a few minutes, then they were much easier to pull free. The Lisle tool worked like a charm for the broken plugs. I decided to go ahead and change the plugs in my 2005 Lariat today. Only broke 3 plugs on that one. Glad thats over with. Thanks for your help.
