6 inch pro comp stage 2 rear lift question
Old Mar 2, 2013 | 04:14 PM
BuRDeN04FX4's Avatar
Alright so my lift just arrived I cant wait to get started. I know the rear is gonna sit lower than the front and I cant have that. whats the Best option to do? I dont want to stack blocks so its either 1 big block or add a leaf or new leafs that will bring the rear end up to match the front.
Thanks everyone
Matt
Old Mar 3, 2013 | 01:40 AM
tman07f150's Avatar
I would add a 1 inch block, just my opinion would be easier, people sometimes stack blocks in back when they level the front. The lift is designed to sit the truck level after lift if going on a stock truck not leveled so it should be close to level if you truck is stock, maybe a tad lower. To much and rear sitting higher. A solid 4 inch block with 6 inches in front should give a level truck.
Old Mar 3, 2013 | 10:45 AM
fxangel's Avatar
lift
You can lower your front to match the rear with that blocks that came with it .And still clear 35' 12.50 9 inch wide wheels. or add a leaf with blocks.Or crack your coil overs to the maximum .. and clear a37'S x13.00 w/ 10 inch wide wheels . I got same set up .and already got experience on those
Old Mar 3, 2013 | 05:51 PM
Ryan_James's Avatar
I'd love to see some pictures when your done. 5.4?? Your truck must be pretty quick being is a regular cab.
Old Mar 3, 2013 | 09:27 PM
760red150's Avatar
Here is mine, I have the same lift with i think the 4in block. Pretty close to level.
Old Mar 10, 2013 | 08:37 PM
I dont want to lower the front to match the back. I ordered 5 1/2" blocks to bring the rear up the fx4 sits different than a normal f150 ive seen many trucks with the front sitting up higher. I think it will be alright. its is a 5.4 ill post up pics when im done for sure
Old Mar 13, 2013 | 07:18 PM
Thadragon's Avatar
Here's Mine with the same lift.
Size:  87.8 KBName:  IMG_0198.jpg
Old Mar 16, 2013 | 08:20 AM
Thadragon did you put the 5.5 blocks in the rear?
Old Mar 18, 2013 | 04:07 AM
Thadragon's Avatar
Actually NO. all i install are the ones that comes with the 6" lift
