This may have been covered...But i didn't see it.
Old Oct 25, 2012 | 08:44 PM
deaverz's Avatar
So,
sorry about that. My question is on my 06 FX4 Screw, I have a dinging noise like you would get when your fuel is low but it dosen't show up on the idiot display. It does this 3 or 4 times before it stops. I'm thinking it may be tied in with my water temp, as that's the only change I notice. i would love to know what it is....
If you can help,
Thanks.
Old Oct 26, 2012 | 06:42 AM
ZRXKUMA's Avatar
seat belt chime?
Old Oct 26, 2012 | 10:47 PM
deaverz's Avatar
well, it was warmer today, no dinging noise, so I believe it has something to do with my water temp, which is odd. It's odd, as no notice on the idiot display, and as soon as my temp rises above the bottom mark on the scale it stops.
On another note, this truck also shutdown while driving before, didn't matter the speed, just shutdown. I first thought it was the tranny, then possibly the computer, it would do this once a week. Turns out it was the battery. Never had a vehicle that did that. Since I replaced the battery, it hasn't happened since, and it's been almost two months since I replaced it.
Anyone know of an unofficial "book" or something that lists things the truck will do to alert you of issues that don't display?
Old Oct 26, 2012 | 10:49 PM
deaverz's Avatar
I thought so too...
Originally Posted by ZRXKUMA
seat belt chime?
At first, then when it repeated for 5 minutes after I put my seat belt on, that couldn't have been it.
Old Oct 26, 2012 | 11:32 PM
jgger's Avatar
If you turn the key to the on position does the air bag light come on for a few seconds?
If the bulb is burned out it can do something like that........just a guess.
Old Oct 26, 2012 | 11:36 PM
deaverz's Avatar
yes, it will blink for a few and yesterday it stayed on, but today it didn't.
Old Oct 26, 2012 | 11:47 PM
jgger's Avatar
Put it on a good code reader, it may have a "B" or "C" code stored or pending.
The Auto Zone readers won't do it, they only read "P" codes.
Good luck.
Old Oct 26, 2012 | 11:53 PM
deaverz's Avatar
Thanks, will update when I figure it out, if you or anyone else has an idea, please don't hesitiate.
Old Oct 27, 2012 | 12:15 AM
Your airbag bulb has an intermittent connection.
Old Oct 27, 2012 | 12:16 AM
LUVmyDUX's Avatar
Could it be the tire pressure monitor? When the outside temperature drops sometimes my wife's Audi will indicate low tire pressure when in fact there's enough air. The light sensor and chime goes away when the temp rises above 40
Old Oct 27, 2012 | 09:51 AM
deaverz's Avatar
my vehicle doesn't have a tire pressure sensor.
Old Feb 7, 2015 | 12:03 AM
deaverz's Avatar
Update (after a year)
Well, just got back for deployment and time to fix the dinging again. Ford had it for a month and couldn't replicate or fix it. I got in the truck and it did it. The mechanic just stared, tried to figure it out but no codes, no issues on their code readers. Still has the 90 seconds of dinging broken up into three times, and every now and then a dim airbag light will come on and then go out. It doesn't do it all the time. Anyone got ideas?
Old Feb 7, 2015 | 03:43 PM
Pretty bad if the Ford dealer can't figure it out.
Old Feb 7, 2015 | 03:51 PM
deaverz's Avatar
yeah tell me about it.
I swear its airbag related but cant find anything to prove it. Reallllly want the beeping to stop, it really annoys the **** out of you.
Old Feb 7, 2015 | 06:18 PM
Have you checked the airbag light bulb yet?
