need help with heated mirrors
Old Oct 25, 2012 | 06:33 PM
STEVCHER's Avatar
just upgrade my 2005 xlt with tow mirrors with power ,turn and heat.
first i moved plug wire #2 to #8 position to get signals to work
my ? is no heat .is it because i only have a six wire factory plug harness and
the factory prewire mirror plug with heat is 8 wire. is it possible to just run a
hot from mirror to rear defrost button.
Old Oct 25, 2012 | 07:32 PM
sampson01's Avatar
Search and you shall recieve thy answer
Old Oct 26, 2012 | 02:44 PM
STEVCHER's Avatar
thanks for all your knowledge you have been a big help.
Old Dec 14, 2012 | 12:49 AM
fordman74's Avatar
Hey guys. I jus bought an 05 SCAb, and will be adding heated mirrors, along with the rear defrost. What is the part number for the heater button, which I believe is part of the control module? Will this be able to also control the rear defrost?
Old Dec 14, 2012 | 01:17 PM
sam1947's Avatar
You will also need the fuse box assembly as the fuse space in the current box is not wired. I had to do the same thing.....entire fuse box and HVAC control assembly. Not sure on an 05, but my 07 had the wiring in the harness, just needed the box and the control.
04f150owner's Avatar
your best bet is to contact a ford dealer to get the correct part number. i have an 04 f150 screw and added heated mirrors and ordered a new hvac control head to get the heated mirrors to work, it was used and then my hvac system didn't work properly, turns out they have different p/n's through the years so i had to order a new one and cost around $250. i think you can get them the button controls heated mirrors and back glass. i know alot of the guys around here recommends tasca ford.
Old Dec 14, 2012 | 06:38 PM
sam1947's Avatar
You should call TascaParts.com and get a quote. The HVAC control is around $250 +/- and the fuse/relay box is around the same, possibly less complete with fuses and relays. I know it cost me around $550 for the conversion.
Old Dec 14, 2012 | 07:42 PM
Tailrace's Avatar
There are a bunch of threads about what you're trying to do, and the search feature is the best way to get all the info you need.
Old Dec 17, 2012 | 09:26 AM
fordman74's Avatar
Thanks for the info guys. I found a heater control out of a 35k mile 05 SCAB from a local wrecking yard, and they may have the fuse box out of the same truck. I will keep you all posted. I am going to install the 13 powerscope mirrors on my 05, so stay tuned!!
