Engine Running Rough and Dying out at Stop
Old Oct 13, 2014 | 11:52 AM
JB1ack's Avatar
Originally Posted by slo5oh
When it runs rough at idle can you do a quick stab on the gas and clear it up? Then sometimes when it drops back down it's smooth, other times it's rough again? I don't wish this on anyone, but you might want to start reading about the camphasers.
Im leaning more towards a vacuum leak. I replaced the MAF this weekend. It still idles rough and will die If you rev it up and let off the gas. I also started to have gas fumes come through the vents. I read on another forum that gas fumes with the rough? dying idle is the MAF. But I swapped that out and no changes. Any ideas? its a 2006 f150 5.4L. Thanks
Old Oct 13, 2014 | 11:57 AM
Gas fumes could be leaky/stuck injectors.
Old Oct 13, 2014 | 04:12 PM
slo5oh's Avatar
I had gas fumes coming into my 06 truck about a week after the dealer put a new engine in it. They found a broken fuel pressure regulator, actually I think they used the term "cracked".
